22934 Discussions
Enable "Panel Fitting" on "Intel Graphics Accelerator Driver" install switch, .inf .cfg, reg key???
Is there a way to enable "Panel Fitting" (Aspect Ratio or Full Screen with no border), during the installation of the "Intel Graphics Accelerator Driver"? I'm using the -res 1024x768x32x60 -s installation switches during setup to set my resolution and that works fine. However, because Panel Fitting is disabled by default I have to manually go in after the driver has installed to enable it. Otherwise the screen maintains the aspect ratio and gives me borders. I've been looking for a separate install switch, or something that I can write into an .inf or .cfg file or possibly a .reg key I could change. I'm deploying the driver to an enterprise so manually changing the setting is not practical.
Any ideas???
