23660 Discussions
Error with opengl32.dll
DSust1
processor: i3 6006u
Intel HD graphics 520
I'm trying to run games that use Opengl32.dll what I see the error "Cannot find opengl32.dll, please re-install application" But, file opengl32.dll it is available in both system32 and SysWOW64.
Changed the file and when trying to register in the system "the Module is loaded but the dllregisterserver entry point is not found".
Demolished the driver and put the latest version of the result did not give.
Stefan3D
opengl32.dll is provided by Microsoft, not by Intel (right-click and check properties/details to confirm).
Which games cause trouble and are they from the same or different developers?
Check your OpenGL status with GPU Caps Viewer 1.44.3.1
DSust1
At startup GPU_Caps_Viewer.exe "Error when starting the app (0xc000007b). "
Stefan3D
Stefan3D
Otherwise re-install the graphics driver
(ig9icd*.dll is dependent on opengl32.dll)
DSust1
I completely deleted the drivers and downloaded them again, but it didn't help.
Stefan3D
If OpenGL worked earlier and problems started recently, you can "restore from a system restore point".
If it is a fresh Windows installation, then i don't know.
SBloo1
Effective and interesting post for reading, i really love it and waiting for updates dqfanfeedback
