20657 Discussions
Für dieses Gerät sind nicht genügend Ressourcen verfügbar. (Code 12)
kwifi
Fehlermeldung Grafikkarte,gibt es eine Lösung des Problems?
Intel(R) Core(TM) i5-2300 CPU @ 2,80GHz 3,00 GHz
RAM 4,00 GB
64 Bit Betr.System
Gigabyte Ultra Durable 3 Motherboard
Grafikkarte: Intel(R) HD Graphics, PCI-Bus 0, Gerät 2, Funktion 0
Wenn Sie dieses Gerät nutzen möchten, müssen Sie ein anderes Gerät mit Anschluss an den Computer deaktivieren.
Danke
Jose_H_Intel1
I understand your Intel® HD Graphics controller is presenting Code 12 in Device Manager.
You may try uninstalling and reinstalling the driver, reloading your BIOS settings back to default or clearing CMOS (but take note of the settings you had changed before doing so!). You may also disable the device that is supposedly using the same resources.
https://technet.microsoft.com/en-us/library/cc732199%28v=ws.10%29.aspx https://technet.microsoft.com/en-us/library/cc732199%28v=ws.10%29.aspx
Please respond the following if the issue persists:
  • Was Intel® HD Graphics working properly before? If yes, was any hardware or software added or changed?
  • What is your operating system?
kwifi
Hallo,
habe dieselbe Graphic und Software wie vorher.
System: Windows 7
LG
kwifi
Hallo,
System: Windows 7
LG
Jose_H_Intel1
kwifi
Hallo,
System: Windows 7
LG
kwifi
Hallo,
System: Windows 7
LG
Jose_H_Intel1
Try this Microsoft* utility: https://support.microsoft.com/en-us/mats/hardware_device_problems Hardware devices are not working or are not detected in Windows
Use this alternate driver installation method if the above does not help: http://www.intel.com/support/graphics/sb/CS-033915.htm Graphics Drivers — How to Manually Install a Driver in Microsoft Windows 7*
Latest driver: https://downloadcenter.intel.com/download/24696/Intel-HD-Graphics-Driver-for-Windows-7-8-8-1-64-bit https://downloadcenter.intel.com/download/24696/Intel-HD-Graphics-Driver-for-Windows-7-8-8-1-64-bit
Jose_H_Intel1
