23793 Discussions
FFmpeg QSV embedded EIA-608 caption decoding/transcoding
r00tb33r
I have the following situation.  I have H.264 files in .ts container that contain in-band EIA-608 (A/53 / DTVCC Transport) captions.  I need to transcode the files with QSV into MPEG-2, retaining the captions.
Per official transcode examples:
https://trac.ffmpeg.org/wiki/Hardware/QuickSync
Using FFmpeg 5.0 stable:
ffmpeg -hwaccel qsv -qsv_device 1 -codec:v h264_qsv -i in1.ts -codec:v mpeg2_qsv out1.mpg
Stream #0:0[0x44c]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], Closed Captions, 29.97 fps, 29.97 tbr, 90k tbn
(no separate subtitle/captions stream)
Resulting output file does not contain captions.  I am trying to utilize QSV decoding and encoding.
I also tried with -a53cc 1 flag, but also no captions in the output file.
ffmpeg -hwaccel qsv -qsv_device 1 -codec:v h264_qsv -i in1.ts -codec:v mpeg2_qsv -a53cc 1 out1.mpg
For the reference, software transcode without Intel QSV:
ffmpeg -i in1.ts -c:v mpeg2video out1.mpg
Results in an output file with captions.
My QSV hardware is DG1.
Help is appreciated.  Thank you.
Alberto_R_Intel
r00tb33r, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
What is the model of the Intel® processor?
What is the model of the motherboard?
If this is a laptop, what is the model of it?
Is this a new computer?
When did you purchase it?
Were you able to retain the captions previously on this specific machine?
If so, when did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
Which Windows* version are you using?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
r00tb33r
i5-11400F, discrete DG1 "Iris Xe MAX"
Gigabyte Z590 Aorus Master
Not a laptop.
Yes.
March 2022
No, it was built for testing of Intel QSV transcodes.  It has not worked as expected yet.
From the beginning.
Can't think of any.
Windows 10 Pro 21H2
Work environment.  This is a broadcast facility.  We are evaluating Intel graphics products for fitness for production workflow.  FFmpeg is one of the software products Intel is offering support for with the new discrete graphics products.  We are evaluating as potential adopters of the current and upcoming Intel discrete graphics products.
SSU report attached.
Moderator:
Please unlock the following thread, I have additional information to share as I have an up-to-date supported product:
https://community.intel.com/t5/Graphics/ffmpeg-5-0-breaks-QSV-syntax-for-hardware-aceceleration/m-p/1368941
Alberto_R_Intel
r00tb33r, Thank you very much for providing that information and the SSU report.
We will do further research on this matter, as soon as I get any updates, I will post all the details on this thread.
Albert R.
r00tb33r
Here is some additional information you might find useful:
https://www.atsc.org/atsc-documents/a53-atsc-digital-television-standard/
This is the applicable standard.
Each of the applicable decoders and encoders in FFmpeg should support it, including Intel's QSV implementation, and if missing should be fixed with a patch.
Alberto_R_Intel
Hello r00tb33r, Thank you very much for sharing those details.
After reviewing the case and the SSU, we can confirm that this is a Xe MAX graphics controller, however, these cards were not available for desktop end-users, so, just to confirm, is it possible to get some pictures may be of the card?
Did it come integrated with the system you bought/build?
Do you know by any chance if what you received was an engineering sample?
Do you have the option to provide the file you are using for the streams (video file, captions/ subtitles) and instructions on how to run it?
Albert R.
r00tb33r
Attached a picture of one of my DG1 cards.
These came from pre-built system in retail, like this one:
https://www.bestbuy.com/site/cyberpowerpc-gaming-desktop-intel-core-i5-11400f-8gb-memory-intel-iris-xe-500gb-ssd-black/6462676.p?skuId=6462676
These are not engineering samples.  Considering I have run the same tests on integrated UHD 630 with the same results it will probably be of more use to focus on the software side of the QSV implementation.
Yes, here's a test file with embedded captions:
https://drive.google.com/file/d/1jF-rCBuLTli4v9P37rAS4yIf8KQ71AOx/view?usp=sharing
Get FFmpeg:
https://www.ffmpeg.org/download.html
https://www.gyan.dev/ffmpeg/builds/
https://www.gyan.dev/ffmpeg/builds/packages/ffmpeg-2022-04-18-git-d5687236ab-full_build.7z
Get MediaInfo (optional):
https://mediaarea.net/en/MediaInfo/Download/Windows
https://mediaarea.net/download/binary/mediainfo-gui/22.03/MediaInfo_GUI_22.03_Windows.exe
Run the following tests from command line:
QSV-accelerated transcode (test.ts is the input file, qsv.mpg is the output):
ffmpeg -hwaccel qsv -codec:v h264_qsv -i test.ts -codec:v mpeg2_qsv qsv.mpg
Examine the output using MediaInfo or VLC (captions are in the Subtitle menu).
Test expectation: captions present
Test result: no captions present in the output file
Software-only transcode (no QSV acceleration) (output file software.mpg):
ffmpeg -codec:v h264 -i test.ts -codec:v mpeg2video software.mpg
Examine the output using MediaInfo or VLC.
Test result: captions present in the output file
QSV decoder test (output file is qsv.yuv):
ffmpeg -hwaccel qsv -c:v h264_qsv -i test.ts -vf hwdownload,format=nv12 -pix_fmt yuv420p qsv.yuv
Examine the output using VLC (captions are in the Subtitle menu).
Software-only decoder test (no QSV acceleration) (output file software.yuv):
ffmpeg -codec:v h264 -i test.ts -vf format=nv12 -pix_fmt yuv420p software.yuv
Alberto_R_Intel
r00tb33r, Thank you very much for letting us know those aspects and for providing the picture.
We will continue with our research on this matter, as soon as I get more details, I will post all the updates on this thread.
Albert R.
Alberto_R_Intel
Hello r00tb33r, I just received another update on this matter.
While still working on this case, we just wanted to confirm, if you do the same transcoding without QuickSync do the captions remain?
Albert R.
r00tb33r
Yes, the software-only transcode without QSV acceleration results in captions remaining in the output, which is the desired outcome.
With QSV they are missing.
Alberto_R_Intel
r00tb33r, Thank you very much for confirming that information.
We will continue with our research on this matter, once I get more updates I will post all of them on this thread.
Albert R.
Esteban_Intel
Hi @r00tb33r ,
Would you be able to provide a sample of the .TS file with EIA-608 closed captions you are using when seing the issue?
Esteban R.
r00tb33r
@Esteban_Intel wrote:
Hi @r00tb33r ,
Esteban R.
Yes, the sample .TS file has already been provided earlier in this thread:
community.intel.com/t5/Graphics/FFmpeg-QSV-embedded-EIA-608-caption-decoding-transcoding/m-p/1378933#M107364
forartEU
@r00tb33r you can obtain "correct" ffmpeg-commandline(s) easily through (open source) FastFlix GUI, which also let you to take advantage of rigaya's QSVEnc
Esteban_Intel
Hi @r00tb33r ,
Intel QSV encode has the capability to support subtitles, but developers using it need to write the code to add that support.
In your specific case, we advise you to contact the FFMpeg developer for support. Since they need to add support for Closed Caption in their h264_qsv and mpeg2_qsv codecs code.
Esteban R.
