22802 Discussions
Facing Problem on Video Editing in Adobe premier pro(need Urgent Solution)
Riead
Hello i'm facing problem while editing video or rendering .when i'm put the project render gpu doesn't work.but cpu load is 100%.and also i cant checking video rendering all settings.i already checked the latest driver.but didn't get any solution.
my pc configure in CPU: i5 13400f, gpu:Gunnir Arc a770 16gb.Ram: OCPC Pista 32gb premier pro version in 23.(also checked by instaling 25 version)
i attached the Video
JedG_Intel
Hello Riead,
I totally understand that you need urgent solution for the issue that you are encountering. Please share the information below for me to properly address this.
1. Was this working fine before?
2. Have you tried using other editing software to check if the same issue will be observed?
3. What software version of Adobe premiere pro are you using?
Please also generate SSU report for me to check your system components.
Jed G.
Riead
it's not working when i checked for work.before i used GTX 1660 super. that was working properly.my adobe premier pro version is 2023.but i also installed 2025.the performance was same.my ssu report is given bellow
JedG_Intel
Hi Riead,
Thank you for sharing this information.
Based on the SSU logs, I see that you have an outdated graphics driver. Please try to follow the steps below to update the driver.
1. Download the latest driver version 32.0.101.6557/32.0.101.6262
2. Use DDU to uninstall the previous driver
3. Perform clean installation
4. Update your BIOS to the latest version 11.01
Should you encounter the same issue, please create a new thread as this thread will no longer be monitored.
Jed G.
