23854 Discussions
Fallout 76 fix?
Schaschnix
Hallo,
warte schon länger auf ein Update zu Fallout 76 für die ARC A770.
Es ist kaum spielbar mit den Rucklern.
Hatte davor eine RTX drin da hatte ich keine Probleme.
LG
JedG_Intel
Hello Schaschnix,
Bitte beachten Sie, dass ich Sie nur auf Englisch unterstützen kann. Ich habe ein Web-Übersetzungstool benutzt, um diese Antwort zu übersetzen, daher könnte es eine ungenaue Übersetzung geben.
Kindly share the information below for me to address the issue properly.
1. Does the stuttering occur constantly or in specific areas/situations?
2. What frame rates are you getting?
3. Are you playing through Steam, Microsoft Store, or another launcher?
4. Was Fallout functioning correctly before?
5. What graphics settings are you running?
6. Have you tried a clean driver installation using DDU (Display Driver Uninstaller)?
7. Is the issue isolated to Fallout 76?
Additionally, to have a better understanding of your system configuration and components please generate a complete copy of the System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Best regards
Jed G.
Schaschnix
Hello, thank you for working on this.
Yes, I can write in English (it is translated as well).
  1. The stuttering only occurs in-game, with a maximum of 20–60 FPS. In the game menu, the FPS is 500+.
  2. -
  3. The game is played via Steam.
  4. Before the new graphics card, everything worked without any problems. Since installing the new graphics card, the game no longer runs smoothly.
  5. The stuttering occurs on all settings, both max and low.
  6. Yes, I completely cleaned the drivers using a DDU program.
  7. Sometimes this also happens in other games, mostly indie-developed games, for example Cinema Simulator 2025.
Thank you for the help.
JedG_Intel
Hello Schaschnix,
Jed G.
JedG_Intel
Hello Schaschnix,
Thank you for sharing all this information with me. Kindly generate the System Support Utility report and share it with me as it will help with the investigation.
Best regards
Jed G.
JedG_Intel
Hi Schaschnix,
I'm following up with regards to the System Support Utility report. Kindly share this information at your earliest convenience so we can assist you effectively.
Jed G.
JedG_Intel
Hello Schaschnix,
Jed G.
