23753 Discussions
[Feature Request] Add keyboard shortcut for Capture start/stop
Horsemeatburger
System: HP z4G4 workstation (XEON W-2150B, 64GB 4x16GB DDR4 ECC Registered RAM, 3.84TB Kioxia CMR5 U.2 NVMe SSD, Mellanox Connect-X4 10Gbps Ethernet adapter, REBAR enabled
GPU: intel Arc A750 8GB
Arc Driver version: 31.0.101.4502
OS: Windows 11 22H2
Problem description:
In Arc Control, there is a slider control for starting and stopping the capture of screen/audio content into a video file. The need to do this within Arc Control makes this cumbersome as the target application/game has to be minimized to switch back and forth to start and stop a recording, also adding worthless content (recordings of the application swap) to the video file.
Solution/Suggestion:
1. Add a setting to Arc Control which lets the user define a keyboard key/shortcut to start and stop recording
2. Add a setting to Arc Control to enable/disable the display of a "Start Recording" and "Stop Recording" information box on the screen (the info box should not be recorded!).
Jean_Intel
Hello Horsemeatburger,
We appreciate your feedback. We will send your comments to the proper department for them to be aware of your remarks and to keep improving the customer's experience while using Intel products. Let us know if you have any other questions
Jean O.
Jean_Intel
Jean O.
Jean_Intel
We're glad to know the information helped. Hopefully, it will help other community members. Since the thread is now solved, we will close it. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jean O.
