22970 Discussions
Flickering & GPU/CPU Process increase (intel irish xe graphic)
ZiaSaiyed
I am facing issue screen flickering, I found GPU/CPU process incease.
I disable all background, clean & update driver but same issue.
I checked on Safe Boot, no issue found.
Screen flickering when I worked on Facebook Ads Manager with any of Browser, I checked all browsers. Once its started It flickering continue till restart.
pedroalono
Hey,
It sounds like you have tried some common troubleshooting steps already, but the issue persists. Here are some additional steps you can try to troubleshoot the screen flickering:
  1. Check for malware and viruses: Malware and viruses can cause various issues with your computer, including screen flickering. Use a reputable anti-malware software to scan your computer for any infections and remove them if detected.
  2. Update your BIOS: Outdated BIOS can cause screen flickering and other issues. Visit your computer manufacturer's website to download and install the latest BIOS version for your computer.
  3. Adjust display settings: Try adjusting the refresh rate and resolution of your monitor. Sometimes the default settings can cause issues with certain applications. Also, make sure that your monitor is properly connected and configured.
  4. Disable hardware acceleration: Hardware acceleration can sometimes cause issues with certain applications. Try disabling it in your browser settings and see if the screen flickering stops.
  5. Update your graphics card driver: Visit the website of your graphics card manufacturer to download and install the latest driver for your graphics card.
If none of these steps work, you may want to consider contacting a professional technician for further assistance.
