23722 Discussions
Flickering problems
PCost4
Hello.
I got a i7-7500U CPU 2.70Ghz; 16 GB RAM; hd graphics 620
I am playing Skyrim but I can't because is always flickering the characters/actors.
What can I do to solve it?
Stefan3D
Check out:
https://bethesda.net/community/topic/8825/editing-large-references-causes-lod-to-show-incorrectly-causing-texture-flicker Editing "large" references causes LOD to show incorrectly causing texture flicker | Community Beta for Bethesda.net
PCost4
That does not solve my problem. I have already tried.
It says that it's not valid for my PC and take me to this page:
https://www.intel.com/content/www/us/en/support/graphics-drivers/000005469.html Error Message: Computer Manufacturer Graphics Driver Detected
Stefan3D
Create a system restore point
https://support.microsoft.com/en-us/instantanswers/e6bbddb0-9db4-4d88-9063-42c52c79a96e/create-a-system-restore-point
Install the aforementioned driver via "have disk method" as described at:
http://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
PCost4
It worked. I was trying to solve this since 2 days ago.
Thank you so much!
Stefan3D
Thank you so much!
No problem.
I suggest to make a note at to avoid confusion.
