23817 Discussions
Freeze with Intel Graphics 3000
Hello everyone.
I have this configuration:
Processor: Intel 2500K
Motherboard: AsRock Z77 Pro4
I have 1 monitor and 1 TV. The monitor is plugged into HDMI port. The TV is plugged into DVI port.
My problem is that at random (almost every time I watch videos) the system freezes for more or less 30 seconds (mouse and keyboard). After that I can continue with my stuff.
I tried the old drivers but it gave me the problem "No Display after loading Windows 7". Now I'm using the last available drivers.
What can I do?
Thank you in advance for every answer.
is your motherboard Bios up to date ? the lasted version is 1.20.
Go to bios menu Advanced and set...
primary Adapter = iGFX
share memory = select Highest MB
iGPU Multi-Monitor = enable
Render Standby and Deep Render = enable
Yes...Bios is up to date.
And all the option are enabled (with 1024 MB as "share memory").ò
I made a few test and I realized that the problem is only when I choose the "clone mode" (win+P).
The system don't let me choose my monitor as primary output. Even if I choose the monitor, when I do "win+P" and select "Just Computer", I can see only with my TV.
I tried choosing "Just projector" and in this way I can see with my monitor. In this in this case it seems there are no problems, but I would like to set "clone mode" all the time (like I use to do on my old PC).
have you tested with your TV on HDMI and your Display with DVI connect ?
My current cable is too short to try. I'll buy a longer one and I will try in a few days
