22796 Discussions
Full HD in Clone Displays Mode
I have a Intel Desktop Board DH55TC. I only use the onboard graphics.
My OS is Win7 Prof. 32 Bit.
I have plugged one Monitor by HDMI and the other one by DVI.
Both Monitor are able to show FullHD (1920/1080).
First Monitor: LG Flatron W2442PA
Second Monitor: AOC 2436 Pwa
If only one of the Monitors plugged, the Monitor show the Screen in FullHD.
If both Monitors in Clone Display Mode plugged, the max. resolution is 1680/1050
Has anyone an Idea how i could have FullHD on both Monitors in the Clone Display Mode?
greets
Frank
The Problem is solved.
I tried to change the resolution a few days later. At some reason the FullHD resolution appears.
Frank
How is the clarity of text.....though video is FullHD text reqsolution is bad for me. I have DH55TC board connected to Sharp Aous FullHD through HDMI cable. As I said, the text resolution is very poor, blurry text. Are you connected using HDMI or DVI? Did you find any diff between these two cables? Have you faced such issue?
