23839 Discussions
Full HD performance ?
kbela
Please help!!! This config:
HP Compaq
6000 Pro SFF
- Intel Dual Core E5400 CPU
- Intel® Q43 Express chipset
- 2GB DDR-3 1066MHz memory
- 320GB SATA 7200rpm HDD
- DVD-ROM
- Realtek ALC261 HD Audio
- Broadcom 82576LM Gigabit Lan
- Intel integrated graphic
- D-Sub, Display Port VGA out
- 1 x PCI 2.3, 2 x PCI-e x1 slots
- 1 x PCI-e x16 LP, 10 x USB 2.0
- 240W active PFC
is enough for smoothly play Full HD 1080p movies with Displayport --> HDMI adapter, connected to a Full HD TV ???
If true, then with how many % CPU work ???
The integrated graphic of Q43 chipset is how much slower than the X4500 ???
Thx
Greetings to everyone!!!
Hans_B_Intel
Hello kakas88,
The maximum resolution amount depends on many factors, such as chipset, monitor capabilities, and manufacturer configurations. Check with your computer and display manufacturers to find out what the maximum resolution is for both the computer and display.
You can go here for information on the different graphics specification for each chipset: http://www.intel.com/support/graphics/sb/CS-033757.htm http://www.intel.com/support/graphics/sb/CS-033757.htm
