23854 Discussions
Fuzzy text problem with latest drivers
MKhva
Lenovo v570 (core i5 2410M), Windows 7 x64. With latest drivers (15.26.8.64.2696, 15.26.12.64.2761) the text is a few fuzzy. With older drivers (15.22.52.64.2559) i have no this problem. The same problem on Windows 8 x64 with 15.28.0.2770. Setup ClearType doesn't help.
Latest drivers (first photo). Older drivers (second photo).
Any solution?
ROBERT_U_Intel
Hi
Could you verify the Scaling setting in the Intel Graphics and Media Control Panel (GMCP)?
To access, right click on the desktop, click Graphics Properties, and the GMCP will open. If you are using more than one display, make sure the display you see the issue on is selected in the Display drop down. The correct setting should be Maintain Display Scaling.
MKhva
already verified 😞
ROBERT_U_Intel
OK,, is this a single display on the laptop or do you also have an external display connected?
MKhva
Single display on the laptop
MKhva
Same problem with new drivers - 15.28.8.64.2875
MKhva
Problem isn't gone with new drivers. Intel ignores it?
