22961 Discussions
GL_ARB_uniform_buffer_object not supported in glsl
Hello
This extension is exported in GL_EXTENSIONS, but not known in GLSL:
WARNING: 0:3: extension 'GL_ARB_uniform_buffer_object' is not supported
Uniform buffers objects are full working in "# version 140" shaders, but this warning still exists. But on lower glsl versions, uniform buffers can't be used.
A correct OGL implementation have to provide this extension in all glsl versions or isn't allowed to export this extension (but still OpenGL3.1 would be fine)
ROBERT_U_Intel
Hi Markus
What OS/ What Chipset Graphics? What Driver version?
Hi Robert,
sorry:
OS: Windows 7
GPU: HD 3000
Driver: 9.17.10.2932
x64 build
ROBERT_U_Intel
Hi Markus
Instead of using:
extension GL_ARB_uniform_buffer_object : require
You could use:
extension GL_ARB_uniform_buffer_object : enable
If you use require the compilation will fail if there's a warning, with enable the compilation won't
fail and the feature can be use regardless of the compilation warning.
Of course this is a driver bug
and it will be fixed.
Hi Robert
I now check GL_VENDOR for Intel and change the GLSL version to 140.
However, it would be nice to see UBO support in GLSL 130. So I may be able to remove the workaround.
