23807 Discussions
GLSL compiler rejects valid input program
ADona4
I find that the following (valid) piece of GLSL is rejected by then Intel GLSL front-end:
# version 150
void foo() {
vec4 temp = -(mat3x4(0.0)*vec3(0.0));
I get this error:
ERROR: 0:4: '' : unary '-' not allowed for provided data type
Interestingly, if I rewrite the code like this:
# version 150
void foo() {
vec4 temp = (mat3x4(0.0)*vec3(0.0));
temp = -temp;
then it is accepted by the front end.
I have an Intel(R) HD Graphics 520 GPU, and I am running driver version 20.19.15.4326 (18/11/2015).
Can others reproduce this, and do you agree that it is a compiler bug?
Stefan3D
I can confirm that with HD5500/v4364
NVIDIA compiler accepts it (it's sloppier in general)
Try this:
vec4 temp = -1.0 * (mat3x4(0.0)*vec3(0.0));
ADona4
Thanks for confirming that you can reproduce this.
Even if the NVIDIA compiler is sloppier in general, it seems that the Intel compiler is wrong in this instance, agreed?
