23089 Discussions
GLSL compiler reports error when declaring arrays without length using Type[] VarName syntax
Yong_H_
In GLSL, if you declare an array without specifying its length using the Type[] VarName syntax, compiler will always report error. Changing the declaration to Type VarName[]; would work around the issue.
System Setup Information:
System Used: (Manufacturer/Model) Sony Vaio Pro 13
CPU SKU: (i3, i5, Pentium, Celeron, etc.) i7 4500U
GPU SKU: (HD4400, HD5100, etc.) HD4400
Processor Line: (Y-Series, U-Series, etc.) U-Series
System BIOS Version: N/A
CMOS settings:N/A
Graphics Driver Version:20.19.15.4444
GOP/VBIOS Version: N/A
Operating System: Windows 10 1607
OS Version:
API: OpenGL
Occurs on non-Intel GPUs?:No
Steps to Reproduce:
1. Create an GLSL shader with following content:
buffer inputBuffer {
​    vec4[] buffer;
​out vec4 outputColor;
void main() { outputColor = buffer[0]; }
2. Compile the shader with glCompileShader function
Expected Results: The shader should be compiled successfully.
Actual Results: Driver reports shader compilation error : "array without length"
Additional Information: N/A
Michael_C_Intel2
Hi Yong,
I have filed a report and ma talking with the driver team about the issue. We may need additional information as we begin investigating, a sample binary or code would help us replicate the issue quicker. I will update you when I learn more.
-Michael
