22923 Discussions
GLSL: "layout(rgba16f)" wrongly shows warning and crashes
Gerasimov_M_
Example:
uniform layout(rgba16f) image3D dest;
Result:
SHADER_ID_COMPILE other warning has been generated. GLSL compile warning(s) for shader 20, "/$$rp/rpplugins/scattering/shader/eric_bruneton/add_delta_sr.compute.glsl": WARNING: 0:38: 'image format' : redundant image format layout qualifier
Since this qualifier is valid there's no warning should be. Code shouldn't also lead to crashing.
Windows 10, Intel HD 4600, latest drivers.
Michael_C_Intel2
Hi again Gerasimov,
Like your other post I need you to fill in the template below. This will help us investigate the issue.
-Michael
System Setup Information:
System Used: (Manufacturer/Model)
CPU SKU: (i3, i5, Pentium, Celeron, etc.)
GPU SKU: (HD4400, HD5100, etc.)
Processor Line: (Y-Series, U-Series, etc.)
System BIOS Version:
CMOS settings:
Graphics Driver Version:
GOP/VBIOS Version:
Operating System:
OS Version:
API:
Occurs on non-Intel GPUs?:
Steps to Reproduce:
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Expected Results:
Actual Results:
Additional Information:
