23096 Discussions
GMA 4500MHD - OpenGL - GL_EXT_packed_depth_stencil - Problems
Since the new driver release my gma4500mhd now lists support for the ogl extension GL_EXT_packed_depth_stencil. After running a short test OpenGL reports unknown enum if i try to create a renderbuffer using the format GL_DEPTH24_STENCIL8_EXT. It would be nice if someone could explain this to me.
I'm trying to use a depth and a stencil buffer for a fbo since i bought this laptop without success.
If someone knows a way to setup a complete fbo with depth and stencil buffer please let me know.
If needed I'm going to write an example program for GL_EXT_packed_depth_stencil.
I'm running Windows7 Prof. with the current 8.15.10.2086 drivers
Hello, nnexai.
I was having probably the same problem with an application at my office today.
I'm trying to run the app on a laptop with an intel Core i5 and GMA HD graphics, running Windows XP.
Not sure about the graphics driver version because I'm currently writing this at home.
Here's a snippet similar to the code I'm having trouble with:
glGenTextures( 1, &tex ); glBindTexture( GL_TEXTURE_2D, tex ); glTexImage2D( GL_TEXTURE_2D, 0, GL_RGBA, tex_w, tex_h, 0, GL_RGBA, GL_UNSIGNED_BYTE, 0 ); glGenRenderbuffersEXT( 1, &rb ); glBindRenderbufferEXT( GL_RENDERBUFFER_EXT, rb ); glRenderbufferStorageEXT( GL_RENDERBUFFER_EXT, GL_DEPTH24_STENCIL8_EXT, rb_w, rb_h ); glGenFramebuffersEXT( 1, &fb ); glBindFramebufferEXT( GL_FRAMEBUFFER_EXT, fb ); glFramebufferTexture2DEXT( GL_FRAMEBUFFER_EXT, GL_COLOR_ATTACHMENT0_EXT, GL_TEXTURE_2D, tex, 0 ); glFramebufferRenderbufferEXT( GL_FRAMEBUFFER_EXT, GL_DEPTH_ATTACHMENT_EXT, GL_RENDERBUFFER_EXT, rb ); glFramebufferRenderbufferEXT( GL_FRAMEBUFFER_EXT, GL_STENCIL_ATTACHMENT_EXT, GL_RENDERBUFFER_EXT, rb );
This code works perfectly on other graphics boards I tested: a GeForce 7950 GT, a Quadro FX 4500, and a Radeon HD 4650.
After wrestling with the code for half a day, I decided that I can find an alternative to the stencil attachment for the application.
The GMA HD just didn't seem to want to work with the depth-and-stencil extension.
I think there is a possibility that there's either a bug in the general GMA OpenGL driver's framebuffer module or,
maybe intel's hardware just plain doesn't support it.
For us passing in GL_DEPTH_STENCIL_EXT instead of GL_DEPTH24_STENCIL8_EXT in to glRenderbufferStorageEXT worked but it crashed freeing the buffer.
