23094 Discussions
GMA945 + external monitor does not work (not even in single display mode)
Greetings everyone, I turn to you in great dispair. Got this small netbook with a GMA 945 chipset, and am trying to plug it to an external Fujitsu Siemens TFT through single display mode. Now the funny thing is, it should be working, but it don't. I have set panel fit options to maintain aspect ratio (since my external monitor does not support the same resolution sizes as my notebook display), but when I plug it an hit the keys to activate it the TFT will just turn black (no suspend mode, its lights flash blue and stay) while the notebook display turns itself off. If I use the intel clone display settings I can manage to get both displays to run at the same time, which is not what I want though. I need be able to just use my external monitor when at my work place. I updated the GMA drivers today from version 6.14.10.4906 to 6.14.10.4926, hoping this would solve the problem. That's a negative. Checked out the other multiple displays option called 'Extended Desktop', won't work at all, TFT turns itself off when I try turn off the notebook display OR the TFT will have mixed up aspect ratios, unable to display even the small 1024x600 resolution of my notebook instead zooming in dramatically (and happily ignoring the maintain aspect ratio setting of my GMA).
My netbook has no viruses, backdoors, my windows seems otherwise fine and flawless (we still talking about a MS OS, so.... just grant me that it runs fine for the moment). Cannot do a format, although I believe that wouldn't help fix the problem at all.
Any ideas, workarounds, solutions to enjoy working with my external TFT and my notebook display switched off then?
I would much appreciate it. Thanks in advance. Oh, below you will find the info that my GMA driver gave me. And should say I'm open to basically anything as long as it does the job. That includes using third party software as long as its verified. Thanks.
Intel(R) Graphics Media Accelerator Driver for Mobile Report
Report Date: 09/06/2009
Report Time[hr:mm:ss]: 12:53:14
Driver Version: 6.14.10.4926
Operating System: Windows XP* Home Edition, Service Pack 3 (5.1.2600)
Default Language: English
DirectX* Version: 9.0
Physical Memory: 1013 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 128 MB
Graphics Memory in Use: 8 MB
Processor: x86 family 6 Model 28 Stepping 2
Processor Speed: 1600 MHZ
Vendor ID: 8086
Device ID: 27AE
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Mobile Intel(R) 945 Express Chipset Family
Video BIOS: 1566.0
Current Graphics Mode: 1024 by 600 True Color (60 Hz)
* Devices Connected to the Graphics Accelerator *
Active Monitors: 1
Active Notebook Displays: 1
* Monitor *
Monitor Name: Plug and Play Monitor
Display Type: Analog
Gamma Value: 2.20
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: 14.0 inches
Vertical: 11.0 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
640 by 480 (75 Hz)
720 by 400 (70 Hz)
800 by 600 (60 Hz)
800 by 600 (75 Hz)
1024 by 768 (60 Hz)
1024 by 768 (75 Hz)
1280 by 1024 (60 Hz)
1280 by 1024 (75 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Supported
* Notebook *
Monitor Name: Digital Flat Panel (1024x768)
Display Type: Digital
Gamma Value: 2.20
Maximum Image Size: Horizontal: Not Available
Vertical: Not Available
1024 by 600 (60 Hz)
Active Off Mode: Not Supported
* Other names and brands are the property of their respective owners.
