23731 Discussions
GPU temperature
Lupimg
Hello, I recently bought a laptop that has an Iris XE graphics, I intend to play some games with it but I'm afraid of the card overheating, I would like to know if there is any way to check the temperature of the card, and if it is not possible to check it specifically, would the temperature of the CPU be the same as that of the GPU? Or would it be a temperature close to it, like 10 degrees higher?
Alberto_R_Intel
Lupimg, Thank you for posting in the Intel® Communities Support.
We will be more than glad to assist you with this matter.
In order for us to provide the most accurate assistance on this scenario, please attach the SSU report so we can verify further details about the components in your platform, check all the options in the report including the one that says "3rd party software logs":
Albert R.
n_scott_pearson
There are many applications - AIDA64, HWiNFO64, HWMonitor, etc. - that will display the temperature information for the CPU and GPU. AIDA64 can also run stress tests that allow you to see what happens throughout.
