23832 Discussions
Grafica integrada
MatiasLowj
Buenas tardes/noche/día, es mi primera ves publicando aquí y estaba necesitando ayuda, resulta que mi placa de video no funciono mas y bueno desinstale el driver y la quita de mi CPU , luego instale el driver correspondiente de mi grafica integrada pero vi que el panel de control no viene en el driver como antes por lo que me puse a buscarlo en la pagina de Intel, encontré el panel de control pero no para mi sistema operativo, Windows 10 32bits solo encontré para 64 alguno podría darme una mano? desde ya muchas gracias, disculpen si no me exprese bien no estoy muy relacionado con el tema de computadoras
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
AndrewG_Intel
Hello @MatiasLowj
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool.
We would like to inform you that due to the Graphics Drivers for Intel® G41 Express Chipset has been discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request. Thank you for understanding.
You can verify this product's discontinuance status at the following links:
Also, please keep in mind that this thread will no longer be monitored by Intel®.
Andrew G.
