23734 Discussions
Graphic card Intel(R) UHD Graphics 605
Peterv63
Graphic card does not configure 2 additional screens on my laptop acer Apire 3.
According to system check the driver to this card is up to date
Who can help?
Jean_Intel
Hello Peterv63
Thank you for posting on the Intel Community. We would be more than glad to help you with your multi-monitor configuration.
  • You mentioned that you did a system check that confirmed that the unit was up to date. Can you share more details about the software application you used to check this?
  • Are you able to set a monitor at a time, meaning that you only plug one additional monitor at a time?
  • Are you using any type of video adapter when connecting the two monitors?
  • To check for more details about your system. For this, please create a report using the Intel®️ System Support Utility (Intel®️ SSU):
    • Download the Intel SSU
    • Open the application and click "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
Jean O.
Jean_Intel
Hello Peterv63,
We hope you are doing fine.
Jean O.
Jean_Intel
Hello Peterv63,
Best regards.
Jean O.
