23818 Discussions
Graphics Command Center - Some features are not supported on non-intel adapters
MikBRPrincess
Today i got a problem on Graphics Command Center while trying to go to "Video" tab, it says "Some features are not supported on non-intel adapters
Is it a bug? Or my device have hardware problem?
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
[Windows 11 is the new Vista]
MikBRPrincess
hi alhill,thanks for replying, here is the file you requested.
AndrewG_Intel
Hello @MikBRPrincess
In regards to this request, we understand that you have opened an internal Web Ticket with us and we will continue to help you through that channel now. We will therefore close this community case. Thank you.
Andrew G.
