23783 Discussions
Graphics Driver Update Failure
deejayehn
Intel Update Failure 2024-02-18_16-23-35 part 2.jpgIntel Update Failure 2024-02-18_16-23-35 part 2.jpg@ACarmona_Intel
deejayehn
my issue? This is my issue...the graphics don't workmy issue? This is my issue...the graphics don't work
ACarmona_Intel
Hello Deejayehn,
Please provide the following details so we can further isolate the issue and provide you with a solution:
  • When did the issue start, and was your system working fine before?
  • Does the issue only happen in a specific game or app?
  • Have you made any changes to the system that might cause the issue?
  • Is it possible that you can share with us a video of the issue that we are having?
  • Please generate an SSU report to help me further analyse important details on your system, such as the OS build number, graphics driver version, errors logged in the system, etc. To generate the SSU report, please refer to the article. How to Get the Intel® System Support Utility Logs on Windows. Please send us the generated SSU.txt file.
We look forward to your response!
Carmona A.
deejayehn
It has been an issue for a few months now. I make digital art. When I try to transfer my files to my external flash drive, most of the files will transfer without any problems, but, probably around 10 to 15% of them will glitch (like the image above) for some weird reason. It has to be a graphics issue. I'm not a computer wizard. This laptop is fairly old and will need to be replaced soon, but, it would be nice to still be able to use this as long as possible.
I'm not able to update the graphics driver.
ACarmona_Intel
Hello Deejayehn,
Thank you so much for the response.
I understand that the issue that we have is important for you to get fix, and I would try my best to help you with that. However, I will need your SSU.txt file in order to review your system details and start my research on our issue, so I may be able to provide you with a solution.
Here's the link on how to generate your SSU file. After generating, please share that SSU text file with me.
By the way, does the issue only happen when you try to transfer your files to your external hard drive?
I look forward to your response!
Thank you, and have a great day ahead!
Carmona A.
ACarmona_Intel
Hello Deejayehn,
We are checking in with you to see if you already have the answers to our questions so we can further isolate our issue.
Thank you, and have a great day!
Carmona A.
Intel Customer Support Technician
ACarmona_Intel
Hello Deejayehn,
We are checking in with you on the graphics driver issue that we have, as we have not heard any response from you.
Carmona A.
ACarmona_Intel
Hello Deejayehn,
We have not heard back from you, so we will close this enquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Thank you, and have a great day ahead.
Carmona A.
