23068 Discussions
Graphics Driver Update is rejected by Norton as containing a virus
Alan_in_Hemel
I am trying to install the following driver update  32.0.101.8247 (WHQL Certified)
Norton is not allowing this update as it says it is infected, see below:
____________________________
Details
Threat name: IDP.HELU.PSE53%s_cmd
Threat type: Miscellaneous - This is malicious software that could harm your data, computer, or network.
Status: Repaired
Detected by: Behavioral Protection
On PC from: 22/10/2025, 10:59
Last Used: 05/11/2025, 11:27
Startup Item: Yes
Many users
Millions of users in the Norton Community have used this file.
Mature
This file was released 2 months ago.
High
The file risk is high.
Activity
Path | Type | Status
C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe | Process | Terminated
C:\Windows\System32\conhost.exe | Process | Terminated
C:\USERS\ALANC\APPDATA\LOCAL\TEMP\__PSSCRIPTPOLICYTEST_X5RUKDGE.0SG.PS1 | File | Deleted
69461D9E122D69762A7D1955C2D67528 | File | Deleted
MikeO
I am running into the same problem
MikeO
Got it to work.  Assuming it was a false positive, I turned off all Norton antivirus options for 10 minutes and the install ran to completion. On my first try, I only turned off Auto-Protect...but that did not work.  I didn't have time for trial-and-error approach to turn them off one at a time.  So, I turned them all off, as shown in the attached sceen paste.  And, that worked.  Did the required reboot. All came up fine and Norton started normallly with all protection options tutned back on.
KennethB_Intel
Hello Alan_in_Hemel,
Thank you for reaching out to the Intel Community Forum. I understand that you are encountering an issue where Norton antivirus is rejecting the installation of the graphics driver version 32.0.101.8247 (WHQL Certified) due to a potential virus detection.
Intel does not provide any disposition regarding third-party software such as Norton. To proceed, I suggest temporarily disabling the antivirus application before installing the latest graphics driver. Once the installation is complete, you may re-enable the antivirus software.
If the issue persists, please provide us the SSU logs of your system. You can find instructions on How to get the Intel® System Support Utility Logs on Windows*
If you have any further concerns or encounter additional issues, please let me know so I can continue assisting you.
Thank you.
Kenneth B.
Alan_in_Hemel
I disabled Norton as suggested above and the installation ran perfectly. I ran a Norton Full Scan afterwards as a precaution and it found nothing. Thanks for your help.
KennethB_Intel
Thank you for the update. I am glad to hear that disabling Norton allowed the installation to complete successfully and that your full scan did not detect any issues.
I will now proceed to close this case. If you need further assistance in the future, please feel free to reach out.
Kenneth B.
