23671 Discussions
Graphics Driver crash while playing Civilization Beyond Earth
LWhit4
The subject line tells the story in a nutshell. I was playing CIV BE and nearing the end of a long long campaign, and the graphics driver crashed. It reported an unhandled exception and, unfortunately, it crashed in such a way that the screen was black. While I could use the task bar to get a peek at the reported error, when I tried to click on it the window reporting the arrow would appear only briefly before it disappeared behind a black screen. CIV BE was running full screen, and I suspect that has something to do with this behavior. I was unable to get any program running and had to reboot the system to get it in a working state again.
My system is running windows 10 and has an i7-4700MQ processor with 16 gigabytes of memory. So that's HD 4600 graphics. The driver is dated 2/2/16 and the version is 20.19.15.4380.
My plan is to restart the program and take another crack at it. I think I've figured out how to beat the game and don't want to give up.
ldw
Hi Idw,
To get more information, please try the Intel® System Support Utility, in the following link you can download it and attach the result in a comment.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Hellen.
Hello, Idw:
I was checking this thread and I would like to know if there is any update regarding the information requested previously.
I look forward to hearing from you.
Esteban C
LWhit4
Hi Esteban,
I haven't had a problem since I modified the settings on the game and the 3d portion of the intel graphics driver. I also had an email from someone in Intel suggesting or affirming the change I had made. What I did is to turn on anti-aliasing in the game (Civ BE Rising Tide) and turned on the 3d setting to override it with 'conservative morphological anti-aliasing'. So it you want to declare it 'fixed' i guess you can. Though it would be good to know the underlying problem was fixed too.
LDW
Ldw I'm glad to know that the issue hasn't come up again, for further assistance do not hesitate to contact us back.
Hellen.
