23789 Discussions
Graphics Issue
Mr_Daylen
Greetings Intel community 👋,
Recently my computer crashed showing  a blue screen of death, with no error code, it went on to restart my machine and after my display went black.
I tried turning my system off and on and restarting it via recovery mode, i have had graphics issues before that resulted in a black screen so i knew this was a graphics issue.
I then went into safe mode and changed from intel hd graphics to Microsoft basic display adapter, but  that basic display adapter really isnt very good, my laptop now struggles to run video and most of my day i on zoom meetings and as a result of changing my adapter my video is extremely pixelated on zoom.
Now whenever i try to switch back to my intel hd graphics my screen goes black and i have to repeat the process of going back into safe mode and changing my driver,
please help,
Daylen : )
AlHill
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
Mr_Daylen
# SSU Scan Information
Scan Info:
Version:"2.5.0.15"
Date:"02/02/2023"
Time:"00:00:13.7897907"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"FUJITSU"
BIOS Mode:"Legacy"
BIOS Version/Date:"FUJITSU // Insyde Software Corp. Version 1.19 , 06/30/2016 12:00 am"
CD or DVD:"HL-DT-ST DVDRAM GUD0N"
Embedded Controller Version:"255.255"
Platform Role:"Mobile"
Processor:"Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz , GenuineIntel"
Secure Boot State:"Not Available"
SMBIOS Version:"2.8"
Sound Card:"Intel(R) Display Audio"
Sound Card:"Realtek High Definition Audio"
System Manufacturer:"FUJITSU"
System Model:"LIFEBOOK E746"
System SKU:"Not Available"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"1.7.31.0"
- "Microsoft Basic Display Adapter"
Adapter Compatibility:"(Standard display types)"
Adapter DAC Type:"ÿ"
Adapter RAM:"0,00 GB"
Bits Per Pixel:"32"
Caption:"Microsoft Basic Display Adapter"
CoInstallers:"display.inf,MSBDA,ÿ,Intel(R) SKL Mobile/Desktop Gra"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"BasicDisplay.sys"
Driver Date:"06/21/2006 02:00 am"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\basicdisplay.inf_amd64_fc93ae411c02f280\BasicDisplay.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.19041.868"
INF:"display.inf"
INF Section:"MSBDA"
Install Date:"Not Available"
Installed Drivers:"Not Available"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"(Standard display types)"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_1916&SUBSYS_18D110CF&REV_07\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"64 Hz"
Refresh Rate - Maximum:"64 Hz"
Refresh Rate - Minimum:"64 Hz"
Resolution:"1366 X 768"
Scan Mode:"Noninterlaced"
Service Name:"BasicDisplay"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) SKL Mobile/Desktop Gra"
- "Memory"
Physical Memory (Available):"3,05 GB"
Physical Memory (Installed):"8 GB"
Physical Memory (Total):"7,91 GB"
- "BANK 0"
Capacity:"4 GB"
Channel:"ChannelA-DIMM0"
Configured Clock Speed:"2133 MHz"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"SODIMM"
Interleave Position:"Not Available"
Manufacturer:"SK Hynix"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"HMA451S6AFR8N-TF"
Serial Number:"39506612"
Status:"Not Available"
Type:"Synchronous"
- "BANK 2"
Capacity:"4 GB"
Channel:"ChannelB-DIMM0"
Manufacturer:"1315"
Part Number:"CT4G4SFS8266.C8FF"
Serial Number:"22232249"
Type:"Synchronous"
- "Motherboard"
BIOS:"InsydeH2O Version 05.05.01Version 1.19"
Caption:"Motherboard"
Chipset:"Not Available"
Date:"06/30/2016 02:00 am"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"FJNB293"
Serial Number:"E5 YBS9"
Status:"OK"
Version:"M3"
- "Networking"
Intel ® Network Connections Install Options:"Not Available"
Intel ® Network Connections Version:"Not Available"
Intel ® PROSet/Wireless Software Version:"Not Available"
- "Bluetooth Device (Personal Area Network)"
Caption:"Bluetooth Device (Personal Area Network)"
CoInstallers:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"bthpan.sys"
Driver Date:"06/21/2006 12:00 am"
Driver Path:"C:\Windows\system32\drivers\bthpan.sys"
Driver Version:"10.0.19041.1"
Index:"0014"
INF:"bthpan.inf"
INF Section:"BthPan.Install"
Installed:"Yes"
IP Address:"Not Available"
IP Subnet:"Not Available"
Last Reset:"01/27/2023 03:42 pm"
MAC Address:"E4:A4:71:69:48:89"
Manufacturer:"Microsoft"
Media Type:
Net Connection ID:"Bluetooth Network Connection"
NetCfgInstanceId:"{0FE8A379-4AAB-4176-BB29-D24C2F914E28}"
Number of VLANs:"0"
PNP Device ID:"BTH\MS_BTHPAN\6&4E4BADB&0&2"
Port:"Not Available"
Power Management (Low Power):"Not Available"
Power Management (Wake On LAN):"Not Available"
Power Management (Wake on Magic Packet):"Not Available"
Power Management Supported:"No"
Product Type:"Bluetooth Device (Personal Area Network)"
Service Name:"BthPan"
Status:"Enabled"
Team Name:"Not in a team"
Temperature:
Type:"Ethernet 802.3"
- "Service Bindings"
Client for Microsoft Networks:
File and Printer Sharing for Microsoft Networks:
Internet Protocol Version 4 (TCP/IPv4):
Internet Protocol Version 6 (TCP/IPv6):
Link-Layer Topology Discovery Mapper I/O Driver:
Link-Layer Topology Discovery Responder:
Microsoft LLDP Protocol Driver:
- "EM8805"
Caption:"Generic Mobile Broadband Adapter"
DHCP Enabled:"No"
Driver:"cxwmbclass.sys"
Driver Date:"01/29/2021 12:00 am"
Driver Path:"C:\Windows\system32\drivers\cxwmbclass.sys"
Driver Version:"10.0.19041.789"
Index:"0003"
INF:"netwmbclass.inf"
INF Section:"wmbclass.ndi"
Installed:"Yes"
MAC Address:"88:BF:81:5E:5C:50"
Media Type:
Net Connection ID:"Cellular"
NetCfgInstanceId:"{65B1748F-3FD9-4A0A-BFB0-3A9640AEFA02}"
Number of VLANs:"0"
PNP Device ID:"USB\VID_1199&PID_9041&MI_0C\6&EBFCD0&0&000C"
Product Type:"Generic Mobile Broadband Adapter"
Service Name:"cxwmbclass"
Status:"Enabled"
Temperature:
Type:"Wireless"
- "Settings"
*SelectiveSuspend:Selective Suspend:"Enabled (1)"
- "Intel(R) Dual Band Wireless-AC 8260"
Access Point:"10:71:b3:f7:3d:61"
Authentication:"WPA2-Personal"
- "Caption":"Intel(R) Dual Band Wireless-AC 8260"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Dual+Band+Wireless+AC+8260"
Channel:"3"
Cipher:"CCMP"
Connection Mode:"Profile"
Default IP Gateway:"192.168.1.1;fe80::1271:b3ff:fef7:3d60"
DHCP Enabled:"Yes"
DHCP Lease Expires:"02/03/2023 11:31 am"
DHCP Lease Obtained:"02/02/2023 11:31 am"
DHCP Server:"192.168.1.1"
Driver:"Netwtw06.sys"
Driver Date:"01/13/2022 12:00 am"
Driver Path:"C:\Windows\system32\drivers\Netwtw06.sys"
Driver Provider:"Intel"
Driver Version:"20.70.30.1"
Index:"0002"
INF:"oem8.inf"
INF Section:"Install_MPCIEX_GENM2AENBT1_8260_AC_2x2_HMC_WINT_64_AC"
Installed:"Yes"
IP Address:"192.168.1.97;fe80::6b1b:f9cb:de4d:b1b3;2c0f:f528:40:ecd6:5508:125:2e12:ae8c;2c0f:f528:40:ecd6:3f38:361d:58f0:dcfd"
IP Subnet:"255.255.255.0;64;128;64"
MAC Address:"E4:A4:71:69:48:85"
Manufacturer:"Intel Corporation"
Media Type:
Net Connection ID:"Wi-Fi"
NetCfgInstanceId:"{8A858BCC-9220-4C42-9AE2-E319B5355B28}"
Network Name:"Captive_Fibre"
Network Type:"Infrastructure"
Number of VLANs:"0"
PNP Device ID:"PCI\VEN_8086&DEV_24F3&SUBSYS_10108086&REV_3A\E4A471FFFF69488500"
Power Management (Low Power):"Active: Yes, Enable: Yes"
Power Management (Wake On LAN):"Active: Yes, Enable: No"
Power Management (Wake on Magic Packet):"Active: Yes, EnableWakeOnMagicPacketOnly: No"
Product Type:"Intel(R) Dual Band Wireless-AC 8260"
Profile:"Captive_Fibre"
Radio Type:"802.11n"
Receive Rate:"115.6 Mbps"
Service Name:"Netwtw06"
Signal Strength:"62%"
State:"connected"
Status:"Enabled"
Temperature:
Transmit Rate:"115.6 Mbps"
QoS Packet Scheduler:
- "Settings"
*DeviceSleepOnDisconnect:Sleep on WoWLAN Disconnect:"Disabled (0)"
*PacketCoalescing:Packet Coalescing:"Enabled (1)"
*PMARPOffload:ARP offload for WoWLAN:"Enabled (1)"
*PMNSOffload:NS offload for WoWLAN:"Enabled (1)"
*PMWiFiRekeyOffload:GTK rekeying for WoWLAN:"Enabled (1)"
*WakeOnMagicPacket:Wake on Magic Packet:"Enabled (1)"
*WakeOnPattern:Wake on Pattern Match:"Enabled (1)"
ChannelWidth24:Channel Width for 2.4GHz:"Auto (1)"
ChannelWidth52:Channel Width for 5GHz:"Auto (1)"
CtsToItself:Mixed Mode Protection:"RTS/CTS Enabled (0)"
FatChannelIntolerant:Fat Channel Intolerant:"Disabled (0)"
IbssTxPower:Transmit Power:"5. Highest (100)"
IEEE11nMode:802.11n/ac Wireless Mode:"802.11ac (2)"
MIMOPowerSaveMode:MIMO Power Save Mode:"Auto SMPS (0)"
RoamAggressiveness:Roaming Aggressiveness:"3. Medium (2)"
RoamingPreferredBandType:Preferred Band:"1. No Preference (0)"
ThroughputBoosterEnabled:Throughput Booster:"Disabled (0)"
uAPSDSupport:U-APSD support:"Disabled (0)"
WirelessMode:802.11a/b/g Wireless Mode:"6. Dual Band 802.11a/b/g (34)"
- "Intel(R) Ethernet Connection I219-V"
- "Caption":"Intel(R) Ethernet Connection I219-V"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Ethernet+Connection+I219+V"
DHCP Enabled:"Yes"
Driver:"e1d.sys"
Driver Date:"01/30/2022 12:00 am"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\e1d.inf_amd64_e64afe811c7e4662\e1d.sys"
Driver Version:"12.19.2.45"
ETrackID:"Not Available"
Index:"0001"
INF:"oem38.inf"
INF Section:"E1570.10.0.1.19H1"
Installed:"Yes"
MAC Address:"FC:08:4A:62:AF:65"
Manufacturer:"Intel"
Media Type:
Net Connection ID:"Ethernet"
NetCfgInstanceId:"{2A581861-B556-43D8-B0E9-7834634815CD}"
Number of VLANs:"0"
NVM Version:"Not Available"
Part Number:"FFFFFF-0FF"
PNP Device ID:"PCI\VEN_8086&DEV_1570&SUBSYS_192D10CF&REV_21\3&11583659&0&FE"
Product Type:"Intel(R) Ethernet Connection I219-V"
Service Name:"e1dexpress"
Status:"Enabled"
Temperature:
- "Settings"
*FlowControl:Flow Control:"Rx & Tx Enabled (3)"
*InterruptModeration:Interrupt Moderation:"Enabled (1)"
*IPChecksumOffloadIPv4:IPv4 Checksum Offload:"Rx & Tx Enabled (3)"
*JumboPacket:Jumbo Packet:"1514 (1514)"
*LsoV2IPv4:Large Send Offload V2 (IPv4):"Enabled (1)"
*LsoV2IPv6:Large Send Offload V2 (IPv6):"Enabled (1)"
*PMARPOffload:Protocol ARP Offload:"Enabled (1)"
*PMNSOffload:Protocol NS Offload:"Enabled (1)"
*PriorityVLANTag:Packet Priority & VLAN:"Packet Priority & VLAN Enabled (3)"
*PtpHardwareTimestamp:PTP Hardware Timestamp:"Disabled (0)"
*ReceiveBuffers:Receive Buffers:"256 (256)"
*SoftwareTimestamp:Software Timestamp:"Disabled (0)"
*SpeedDuplex:Speed & Duplex:"Auto Negotiation (0)"
*TCPChecksumOffloadIPv4:TCP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
*TCPChecksumOffloadIPv6:TCP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
*TransmitBuffers:Transmit Buffers:"512 (512)"
*UDPChecksumOffloadIPv4:UDP Checksum Offload (IPv4):"Rx & Tx Enabled (3)"
*UDPChecksumOffloadIPv6:UDP Checksum Offload (IPv6):"Rx & Tx Enabled (3)"
AdaptiveIFS:Adaptive Inter-Frame Spacing:"Disabled (0)"
AutoPowerSaveModeEnabled:Link Speed Battery Saver:"Disabled (0)"
EEELinkAdvertisement:Energy Efficient Ethernet:"On (1)"
EnablePME:Enable PME:"Enabled (1)"
ITR:Interrupt Moderation Rate:"Adaptive (65535)"
LinkNegotiationProcess:Legacy Switch Compatibility Mode:"Disabled (1)"
LogLinkStateEvent:Log Link State Event:"Enabled (51)"
MasterSlave:Gigabit Master Slave Mode:"Auto Detect (0)"
ReduceSpeedOnPowerDown:Reduce Speed On Power Down:"Enabled (1)"
SipsEnabled:System Idle Power Saver:"Disabled (0)"
ULPMode:Ultra Low Power Mode:"Enabled (1)"
WaitAutoNegComplete:Wait for Link:"Auto Detect (2)"
WakeOnLink:Wake on Link Settings:"Disabled (0)"
- "Operating System"
.Net Framework Version:"2.0,3.0,3.5,4.0,4.8"
Boot Device:"\Device\HarddiskVolume1"
Locale:"United States"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 10 Pro"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"1,25 GB"
Physical Memory (Available):"3,06 GB"
System Directory:"C:\Windows\system32"
Version:"10.0.19044 Build 19044"
Virtual Memory (Available):"2,83 GB"
Virtual Memory (Total):"9,16 GB"
Windows Directory:"C:\Windows"
- "Installed Updates"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB5003791:"Update [10/6/2021]"
KB5005699:"Security Update [10/6/2021]"
KB5009636:"Update [1/20/2022]"
KB5011352:"Security Update [2/9/2022]"
KB5011651:"Update [4/13/2022]"
KB5012170:"Security Update [8/10/2022]"
KB5014032:"Security Update [5/12/2022]"
KB5014035:"Update [6/15/2022]"
KB5014671:"Update [7/14/2022]"
KB5015895:"Update [8/10/2022]"
KB5016705:"Update [9/14/2022]"
KB5018506:"Update [11/9/2022]"
KB5020372:"Update [12/27/2022]"
KB5020872:"Update [12/28/2022]"
KB5022282:"Security Update [1/11/2023]"
- "Processor"
- "Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 78 Stepping 3"
- "Chipset Name":"Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Core+i5+6300U+CPU+"
CPU Speed:"2,501 GHz"
Current Voltage:"1.6 volts"
Driver:"Not Available"
Driver Date:"04/21/2009 12:00 am"
Driver Path:"C:\Windows\system32\drivers\intelppm.sys"
Driver Version:"10.0.19041.2251"
Ext. Family:"Not Available"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"2 x 64 KB"
Level 2 Cache:"2 x 512 KB"
Level 3 Cache:"3 MB"
Load:"10%"
Manufacturer:"GenuineIntel"
Model:"78"
Name:"Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz"
Number of Cores:"2"
Number of Cores Enabled:"2"
Number of Logical Processors:"4"
Processor ID:"BFEBFBFF000406E3"
Revision:"19971"
Serial Number:"Not Available"
Service Name:"intelppm"
Status:"OK"
Stepping:"3"
- "Storage"
- "Kingmax SSD 120GB"
Capablities:"Random Access, Supports Writing, SMART Notification"
Caption:"Kingmax SSD 120GB"
Cylinder - Total:"14593"
Description:"Disk drive"
Driver Version:"10.0.19041.1865"
Error Code:"Device is working properly"
Firmware Revision:"SN7464"
Heads - Total:"255"
Index:"0"
INF:"disk.inf"
Interface Type:"IDE"
Manufacturer:"(Standard disk drives)"
Model:"Kingmax SSD 120GB"
Partitions:"3"
Physical Sector Size:"512"
PNP Device ID:"SCSI\DISK&VEN_KINGMAX&PROD_SSD_120GB\4&18F67075&0&000000"
Policies:"Read Retention Priority=EqualPriority, Write Retention Priority=EqualPriority, Scalar Prefetch=Not Available, Block Prefetch=Not Available"
Sectors - Per Track:"63"
Sectors - Total:"234436545"
Serial Number:"NO0D2127006008DE"
Size – Available:"26,83 GB"
SMART Attributes:"Self-Test: 2 minutes, OK, Short Self-Test: 2 minutes, OK"
Status:"OK"
Tracks - Per Cylinder:"255"
Tracks - Total:"3721215"
- "C:"
Availability:"Not Available"
Caption:"C:"
Compression Method:"Not Compressed"
Description:"Local Fixed Disk"
File System:"NTFS"
Name:"Not Available"
Serial Number:"BC17EF8F"
Size – Available:"26,832103729248 GB"
Volume Dirty:"No"
- "SMART"
0x05 Reallocated Sector Count:0:"50"
0x09 Power-On Hours:4662:"0"
0x0C Power Cycle Count:253:"0"
0xAD Wear Leveling Count:399452668134:"0"
0xAE Power-off Retract Count:0:"0"
0xAF Power Loss Protection Failure:0:"10"
0xB4 Unused Reserved Block Count Total:338:"0"
0xBB Uncorrectable Error Count:0:"0"
0xC0 Unsafe Shutdown Count:35:"0"
0xC2 Internal Device Temperature:40° C:"0"
0xC4 Reallocation Count:0:"0"
0xC7 CRC Error Count:0:"0"
0xCE Flying Height:93:"0"
0xCF Spin High Current:316:"0"
0xD0 Spin Buzz:230:"0"
0xD1 Offline Seek Performance:1:"0"
0xD2 Vibration During Write:578:"0"
0xD3 Vibration During Write:481:"0"
0xE7 Temperature:15° C:"5"
0xF1 Total LBAs Written:2501:"0"
0xF2 Total LBAs Read:2766:"0"
0xF3 Total LBAs Written Expanded:65537:"0"
...#SSU#...
LeonWaksman
Download and install the  Intel® Graphics Driver 31.0.101.2115. Hope it will work as expected.
Leon
Mr_Daylen
Didnt Work Mate, sorry for late response,
Daylen
Mr_Daylen
Mr_Daylen
Wait nevermind idk what just happened i uninstalled the intel graphics driver then went to basic display adapter and the driver disconnected and connected my Igpu, so odd sorry for the hassle i will update if anythign happens after.
Mr_Daylen
Thx ill try.
