23691 Discussions
Graphics driver restart loop
Samubacsi
Hello i have a problem with intel graphics driver or something I have a laptop asus tuf fx505gt. When I install the graphics driver and its doesn’t connected to the charger it works fine, when I plug in its restarting over and over and when I plug out its booting normally. If somebody can help me with a solution I’ll thank it so much.
IsaacQ_Intel
Hello @Samubacsi
IGCC Report: Follow these steps to generate an Intel® Graphics Driver report for the Intel® Graphics Control Panel or the Intel® Graphics Command Center. Report for Intel® Graphics Drivers.
SSU: Please download and scan your system using our tool, Intel® System Support Utility so we can help check your system info first. Once finished downloading, open the tool, click on scan 'Everything', click next, then save the system information to a .txt file. Please provide the .txt file.
This document will be necessary to check your entire system, in order to find possible errors or incompatibilities.
Isaac Q.
IsaacQ_Intel
Hello Samubacsi,
We hope you are doing fine.
Were you able to check the previous post? Please provide the SSU and IGCC reports.
Isaac Q.
IsaacQ_Intel
Hello Samubacsi,
Best regards.
Isaac Q.
