23808 Discussions
Graphics driver
aakra
hi
I need a Graphics driver for Windows 7 64 - bit
These are computer specifications in the link below
file:///C:/Users/AL%20AQSA/Downloads/Detailed-System-Report.html
Note that I got the Graphics driver for Windows 7 32 bit
thanks
AlHill
Provide the complete processor model number.
Doc
aakra
Processor
Intel® Pentium® 4 CPU 3.00GHz
ManufacturerGenuineIntelDescriptionIntel64 Family 15 Model 4 Stepping 9Architecturex64# of Cores1Current Clock Speed2992 MHzCurrent Voltage2.0Level 2 Cache1024 KbLevel 3 Cache0 KbProcessor IdBFEBFBFF00000F49Revision1033AvailabilityRunning at full powerGraphics
Standard VGA Graphics Adapter
AlHill
Ok, I need to know what graphics or chipset you are running.
Also, I believe you have one of these processors, which does not have graphics.
https://ark.intel.com/compare/27508,27497 Intel® Product Specification Comparison
Doc
aakra
GraphicsStandard VGA Graphics AdapterAdapter Compatibility(Standard display types)Driver ProviderMicrosoftDriver Version6.1.7600.16385Driver Date6/21/2006AvailabilityOfflineStatusThis device is working properly. LocationPCI bus 0, device 2, function 0Device IdPCI\VEN_8086&DEV_2582&SUBSYS_009B1025&REV_0E\3&11583659&0&10
AlHill
Go to the start button, run, and enter DXDIAG.
On the display tab, under device, it will tell you the name and chip type for your graphics.\\
Provide that information.
Doc
aakra
Display Devices
Card name: Standard VGA Graphics Adapter
Manufacturer: (Standard display types)
Chip type: Intel(r)915G/915GV/910GL Graphics Chip Accelerated VGA BIOS
DAC type: 8 bit
Device Key: Enum\PCI\VEN_8086&DEV_2582&SUBSYS_009B1025&REV_0E
Display Memory: n/a
Dedicated Memory: n/a
Shared Memory: n/a
Current Mode: 800 x 600 (32 bit) (1Hz)
Monitor Name: LG L177WSB
Monitor Model:
Monitor Id:
Native Mode:
Output Type:
Driver Name: vga
Driver File Version: 6.01.7600.16385 (Arabic)
Driver Version: 6.1.7600.16385
DDI Version: unknown
Driver Model: unknown
Driver Attributes: Final Retail
Driver Date/Size: 7/14/2009 01:38:47, 15360 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-66C2-11CF-9433-2B3DA0C2CB35}
Vendor ID: 0x8086
Device ID: 0x2582
SubSys ID: 0x009B1025
Revision ID: 0x000E
Driver Strong Name: Unknown
Rank Of Driver: Unknown
Video Accel:
Deinterlace Caps: n/a
D3D9 Overlay: n/a
DXVA-HD: n/a
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
AlHill
Ok, I have to apologize. After all of that, I am unable to find a Windows 7 64-bit driver for Intel(r)915G/915GV/910GL Graphics.
One of the Intel support staff may be able to help.
Doc
aakra
Thank you very much
Yours sincerely
Can you help me and give me the direct email for Intel technical support
AlHill
The intel support staff will be by shortly. Just hang in there.
Doc
Hello akrameh
Thank you for contacting Intel Technical Support,
We received your inquiry and I understand that you are looking for information on graphics drivers. Please accept our apologies for any inconvenience this may be causing. We will be more than happy looking for a solution.
Reviewing the information already provided I see that you have Intel® Pentium® 4 and Intel® 915G/915GV/910GL Graphics Chip; searching into graphics drivers for Windows® 7 64bit I regret to inform you, that the graphics controller supports Windows® 2000 and Windows® XP only, you can verify the information on the following link under the part of Legacy Intel Graphics Products.
https://www.intel.com/content/www/us/en/support/articles/000005526/graphics-drivers.html https://www.intel.com/content/www/us/en/support/articles/000005526/graphics-drivers.html
Leonardo C.
aakra
Hi
I'm sorry to tell you that your information is inaccurate because I installed the graphics driver
but on Windows 7 - 32 bit
regards
aakra
Processor
