23702 Discussions
Graphis
BDwan
What do i do if i get the window that says display driver stopped responding and has recovered intel graphics accelerator for windows xp
Kevin_M_Intel
It may be necessary to update the graphics driver. Can you please provide me with the computer brand and model?
Can you attach your dxdiag here?
How to get it?
Dxdiag Report: Type dxdiag in Start Menu> open> Save> Attach using Advanced Editor Options.
Kevin M
BDwan
Here is the file:
Kevin_M_Intel
Thank you for sharing all this information.
Based on the report, your system is running with an old graphics driver version so I recommend you updating it.
Download the latest driver for your controller at this link:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22521 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22521
If you have problems during the installation of the driver, try the steps mentioned here:
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
Kevin M
BDwan
I did not work I installed the driver only difference is that it says windows 7 instead of xp
Kevin_M_Intel
If your Operating System is Windows 7 then you can install the driver provided before and it will show Windows 7.
Are you looking for XP drivers? Here is XP driver just in case:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=20783 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=20783
Kevin M
