23838 Discussions
HD 3000 Driver screen flickering problem
LKhan
I am using dell inspiron laptop. previously i used windows 7 and now i am using windows 8. i have problem with my graphics driver intel HD 3000 which previously was fine in windows 7. when i install updated version of the driver it starts flickering laptop screen very frequently and ultimately i have to restart laptop. to avoid this problem i just unistalled the driver and now i use microsoft basic version of graphic driver. this one has issues such as i dont see sleep option and also i cant adjust brightness of screen. please help me if there is any way to solve the problem with original driver. system information
System Information
Time of this report: 7/10/2015, 17:05:10
Machine name: UMARALI-PC
Operating System: Windows 8.1 Pro 64-bit (6.3, Build 9600) (9600.winblue_r9.150322-1500)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Inspiron 3520
BIOS: BIOS Date: 01/25/13 11:40:32 Ver: 04.06.05
Processor: Intel(R) Core(TM) i3-2370M CPU @ 2.40GHz (4 CPUs), ~2.4GHz
Memory: 4096MB RAM
Available OS Memory: 3960MB RAM
Page File: 2107MB used, 2812MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.17415 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Microsoft Basic Display Adapter
Manufacturer: (Standard display types)
Chip type: Intel(R) Sandybridge/Ivybridge
DAC type: Intel Corporation
Device Type: Display-Only Device
Device Key: Enum\PCI\VEN_8086&DEV_0116&SUBSYS_05551028&REV_09
Display Memory: 256 MB
Dedicated Memory: 0 MB
Shared Memory: 256 MB
Current Mode: 1366 x 768 (32 bit) (64Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: LGD033A
Native Mode: 1366 x 768(p) (60.052Hz)
Output Type: Internal
Driver Name:
Driver File Version: ()
Driver Version: 6.3.9600.16384
DDI Version: 11.1
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: , 0 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71AF4-43CC-11CF-B727-8005ACC2CB35}
Vendor ID: 0x1414
Device ID: 0x008C
SubSys ID: 0x00000000
Revision ID: 0x0000
Driver Strong Name: display.inf:10809047d4324726:MSBDA:6.3.9600.16384:pci\cc_0300
Rank Of Driver: 00FB2006
Video Accel:
DXVA2 Modes:
Deinterlace Caps: {00000000-0000-0000-0000-000000000000}: Format(In/Out)=(YUY2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{00000000-0000-0000-0000-000000000000}: Format(In/Out)=(YUY2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) ...
Hans_B_Intel
Hello LeeKhan,
Have you tried with driver version 15.28.24.4229? If not I suggest installing it manually, the download and instructions are found here:
https://downloadcenter.intel.com/search?keyword=2nd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+3000/2000 https://downloadcenter.intel.com/search?keyword=2nd+Generation+Intel%C2%AE+Core%E2%84%A2+Processors+with+Intel%C2%AE+HD+Graphics+3000/2000
How to Manually Install a Driver in Microsoft Windows 7*
http://www.intel.com/support/graphics/sb/CS-033915.htm http://www.intel.com/support/graphics/sb/CS-033915.htm
Note:
These software drivers are generic versions and can be used for general purposes. However, computer original equipment manufacturers (OEMs) may have altered the features, incorporated customizations, or made other changes to the software or software packaging they provide. To avoid any potential installation incompatibilities on your OEM system, Intel recommends that you check with your OEM and use the software provided by your system manufacturer. Intel and the computer original equipment manufacturer (OEM) may not provide technical support for some or all issues that could arise from the usage of this generic version of software drivers.
