23083 Discussions
HD 4400 driver for Windows 10 32bit
RHaya1
do you have a graphic driver for HD4400(Core i3 4150) for Windows 10 32bit? After upgrading to Windows 10, a crash happens several times per a month and I'm looking for the latest version or another driver that supports HD 4400.
Ryutaro
Stefan3D
This seems to be the latest: https://downloadcenter.intel.com/download/26099/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40- Download Intel® Beta Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.40]
Probably you need to install it manually as described here:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows...
Parapele
You can try Intel Driver Update Utility http://www.intel.com/content/www/us/en/support/detect.html http://www.intel.com/content/www/us/en/support/detect.html
All drivers for HD 4400 for any OS you can see yourself here https://downloadcenter.intel.com/product/81497/Intel-HD-Graphics-4400 https://downloadcenter.intel.com/product/81497/Intel-HD-Graphics-4400
I think Stefan3D is wrong, driver 15.40.26.4474 doesn't support Haswell processors, it starts from Broadwell, Do you actually can manually install that driver?
UPD Actually i was wrong, Stefan3D 100% right. Driver 15.40.26.4474 support Haswell https://downloadmirror.intel.com/26099/eng/ReadMe.txt https://downloadmirror.intel.com/26099/eng/ReadMe.txt
I think last driver is 15.40.28.4501 https://downloadcenter.intel.com/download/26228/Graphics-Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88394 https://downloadcenter.intel.com/download/26228/Graphics-Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88394
From ReadMe32.txt
4th Generation Intel(R) Core(TM) processor family (codename Haswell)
Microsoft Windows* 10-32
Question for tech support, can you do something with driver searching. Right now last driver for HD 4400 and Windows 10 32bit 15.40.12.4326 11/20/2015 and this is not true..
Try yourself https://downloadcenter.intel.com/product/81497/Intel-HD-Graphics-4400 https://downloadcenter.intel.com/product/81497/Intel-HD-Graphics-4400
This is very confusing, questions like this will appears again and again.
Hello Ryutaro,
I understand you are trying to download graphics driver for Windows 10* 32-bit.
Let me apologize for any inconvenience this issue may be causing to you.
Please try installing the graphics driver version 15.40.28.4501 and let me know if you get or not any error message during driver installation https://downloadcenter.intel.com/download/26228/Graphics-Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88394 https://downloadcenter.intel.com/download/26228/Graphics-Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88394
To Parapele:
Thanks for the feedback you are providing. I will forward it to the appropriate support group so they can take it into consideration.
Fred
RHaya1
Thanks for your response. Appreciate it. But, unfortunately the customer have already installed the latest one(15.40.28.4501). And the crash(BSOD) happens several times per a day(sorry not month). Would it be possible to build 32bit version of the driver for Windows 10? I can share the memory dump if you need to.
Ryutaro
Hello Ryutaro,
I am sorry to hear that you are still having issues with your computer.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .xml file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Let me also know if the blue screen of death happens when you are doing something in specific in the computer or if it is random.
Fred
RHaya1
Hi Fred,
Thanks for the response. Attached is the output of the Support Utility. Also I heard that the crash happens more like when having multiple Excel windows opened. If you need anything else, feel free to let me know.
Ryutaro
Hello Ryutaro,
Thanks for the additional information you sent to me.
For some reason HP* does not provide drivers for Windows 10* 32-bit on their website. HP* provides 32-bit drivers for older operating systems, but not for Windows 10*. There is a chance the blue screen of death you are getting might be due to some type of compatibility issue with Windows 10* 32-bit.
Latest graphics driver for Windows 10* 32-bit is currently installed in your computer. I did not find anything unusual when it comes to graphics in the report you sent to me.
At this point the best option would be contacting HP* in order to check why they are not offering Windows 10* 32-bit drivers for your HP ProDesk 600 G1 SFF. Definitely the lack of drivers can cause different problems in the computer. This link will give you their contact information http://www8.hp.com/us/en/contact-hp/support.html http://www8.hp.com/us/en/contact-hp/support.html
Fred
Hello Ryutaro,
I was wondering if you were able to check with HP* why they are not providing drivers for Windows 10* 32-bit. In case you need further assistance just let me know.
Fred
