23493 Discussions
HD 4600 Screen Flickers with Green Dots in Certain Apps
AHaas1
I just finished building my "dream pc" and I'm currently using the HD 4600 graphics from the i7-4790K until the new Nvidia product line launches. I noticed I am getting green dots flashing on certain textures in some games. So far I've only noticed it in Battlefield 4 and Sim City on certain textures. See screenshot below...
I have all current drivers of everything - UEFI, Windows, Graphics driver, etc.
System specs -
Intel i7-4790K
Asus Hero 7 MB
EVGA Supernova 1000w P2
Corsair Vengeance Pro 16gb 2400
Samsung 840 Pro 512g
Windows 8.1 64
HDMI hooked up to AsusPB278
What I have tried -
Reinstalled graphics drivers, including the Beta for HD4600 as well as previous versions.
Changed every resolution, monitor setting, refresh rate, monitor cable, etc.
I'm not sure what is causing this - I'm hoping its just a driver fix or setting that I can change. Anyone else have this problem? Thanks for the help...
Adam
Kevin_M_Intel
Hi ahaas5,
I am sorry you are having problems but let me help you.
I would like to get some more information from your system so can you please provide the dxdiag report?
How to get it?
Dxdiag Report: Type dxdiag in Start Menu> open> Save> Copy/Paste here.
Graphics Report: Right click on desktop> Graphics Properties> Options> Drop Down Menu> Information Center> Save> Open .txt file created> Copy/Paste here.
Kevin M
AHaas1
Dxdiag...
System Information
Kevin_M_Intel
Thanks for the information. We have not received reports from other users related to this so it is an isolate case. However, there are some troubleshooting steps I want you to do:
  1. Make sure you have the latest BIOS for your board.
  2. Update the graphics driver to the latest version. Here is the download link:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24245 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24245
  1. Install the monitor drivers.
  2. Test different video cables and if possible do not use adapters (direct connection between the monitor and the board).
  3. Try the system with a different monitor.
Kevin M
ROBERT_U_Intel
@ ahaas5, Have you had the opportunity to try the latest Intel HD Graphics driver for resolving this issue?
Link for driver:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24348&lang=eng&ProdId=3720 Intel® Download Center
Robert
aJ5
hi
i too have same problem when i install graphic hd 4600 driver
my computer spec
  • Intel® Core™ i7-4700 Desktop Processor
  • intel mother board DB85FL
  • corsair vs650 SMPS
  • 8 GB transcend RAM
  • WINDOW 7 64 BIT
  • 1 TB HARD DISK
i have monitor flickering problem all the time ,i cant even use computer due to this problem....
when i install graphic driver my system hangs , monitor flickers , pen drive socket disconnects
i tried changing cables,installing latest version in intel website and no electric problems
pl solve my problem, having this problem for about 2 months no one can solve driver problem...
Kevin_M_Intel
What is the driver version installed on your computer? Also, have you tried updating the BIOS on your computer?
Here is the latest:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24354 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24354
Kevin M
