23818 Discussions
[HD 620]Screen flickering only on native resolution without vsync
MSilv26
I'm getting some weird pixels on the bottom of the screen, it happens when i run anything on native resolution without vsync. I did some tests provided by the manufacturer and everything is ok, i tried both intel and dell's drivers but i have the same results. It doesn't happen on 1360x768 (native resolution is 1366x768)
https://youtu.be/mvtihDanamk Video
Hello -str,
I understand that when vsync is off the bottom of the screen flickers.
Let me apologize for any inconvenience this issue may be casing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
May I have the model number of the monitor you are using?
What type of video cable are you using between the computer and the monitor?
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
Hello -str,
Thanks for the information you sent to me.
I would like you to try updating some of the computer drivers in a specific order.
Please install this driver first, and then restart the computer http://www.dell.com/support/home/en/us/brbsdt1/Drivers/DriversDetails?driverId=HMDR4 http://www.dell.com/support/home/en/us/brbsdt1/Drivers/DriversDetails?driverId=HMDR4
Install this other driver, and then restart the computer one more time http://www.dell.com/support/home/en/us/brbsdt1/Drivers/DriversDetails?driverId=FP5G5 http://www.dell.com/support/home/en/us/brbsdt1/Drivers/DriversDetails?driverId=FP5G5
Download this graphics driver https://downloadmirror.intel.com/26772/eng/win64_154518.4664.zip https://downloadmirror.intel.com/26772/eng/win64_154518.4664.zip
Install the graphics driver with the steps that are on this YouTube video https://www.youtube.com/watch?v=S1KzoQDjMMY https://www.youtube.com/watch?v=S1KzoQDjMMY
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Let me know if issue persists or not.
Fred D.
MSilv26
I installed everything and issue persists
Hello -str,
I am sorry to hear the issue persists even after updating drivers.
Please let me know if the "Vertical Sync" option on the Intel Graphics Control Panel is set to "Application Settings" or "Driver Settings".
Are you using any specific application that requires either enabling or disabling vsync?
Please also run the following utility and let me know if it finds or not an error https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Fred D.
MSilv26
It's set to Application Settings, Vsync is optional on the app.
Everything went fine on the tests, but i got "
QPI link rate Test - Not supported.
Skipping QPI link rate Test."
Hello -str,
I would like to gather even more information about the issue you are reporting. Please fill out the form that is in the following link and post it on this forum thread /thread/77761 https://communities.intel.com/thread/77761
If possible let me know the name of the application you are using.
Fred D.
Hello -str,
I was wondering if you still need assistance regarding the vsync issue you are having in your computer. In case you still need assistance just let me know.
Fred D.
