23790 Discussions
HD 730 Combine Displays support
mankimank
Hi
Does HD 730 Combine Displays support because I don't see this function in drivers
Jose_Intel
Hello @mankimank
Thank you for posting on the Intel️® communities.
We understand your concern about the Intel® UHD Graphics 730, using the Combine Displays feature in the Intel Graphics Command Center.
Please check this information: How Do I Enable Combined Desktop in IGCC (Intel Graphics Command Center)?
Make sure your drivers are up to date: 31.0.101.4972
If after that you are unable to use the option, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Then, please generate and attach the Report for Intel® Graphics Command Center
Jose B.
Jose_Intel
Hello mankimank
We hope you are doing fine.
Were you able to check the information and update the graphics driver?
Let us know if you still need assistance by attaching the required reports.
Jose B.
Jose_Intel
Hello mankimank
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
