23737 Discussions
HD Graphics 4600 screen flickering error
DBerg5
since the old thread disappeared rather quickly, I will open a new one here.
I have horizontal lines occasionally popping up as soon as something is moving on screen.
It's not really a flickering, they just appear for 1 or 2 seconds and then disappear.
I am not able to make an actual screenshot of it, because it seems the error does only show on screen.
I manipulated a screenshot to show how it looks like:
This can happen inside a video window, but it doesn't happen when it is playing, but when it is paused and the overlay of the player pops up,
then a black or sometimes white line (1 or 2 pixels wide) pops up, as long as the overlay is shown.
This happens in many different applications, Photoshop, Firefox, VLC Player, ACDSee or the Windows Explorer.
Sometimes its only on a picture on a website or a drop-down menu in some program.
Only games seem to be immune to this, I tried a few which did not show any error.
The thing is, I had this on 2 quite different notebooks.
On an MSI-CR61 with a Pentium 3550M + HD Graphics, and now on a Lenovo Thinkpad Edge E540 with a Core i5 + HD Graphics 4600.
Both running on a fully patched Windows 7 x64 SP1 + latest drivers.
I tried out a Linux Boot CD on both systems, on both machines the error is not present under Linux.
Only under Windows 7 x64 SP1. Which makes me think that it's not a faulty screen
I connected the notebook to an external monitor via HDMI, and I am not able to reproduce the error on that.
On the MSI-Notebook I tried the following versions of the Intel Driver: v.15.36.7.64.3960 and v.15.36.3.64.3907
and the one before that, but I can't find out the exact version now.
On the Lenovo Thinkpad I only tried the latest v.15.36.7.64.3960.
Any ideas?
Greetings,
Daniel
Jose_H_Intel1
Hello Daniel, did you test the drivers provided by the http://www.intel.com/support/oems.htm system manufacturer?
Can you try to reproduce it in safe mode or after a clean boot/diagnostic startup?
http://windows.microsoft.com/en-us/windows/start-computer-safe-mode# start-computer-safe-mode=windows-7 Start your computer in safe mode - Windows Help
http://support.microsoft.com/KB/929135 How to perform a clean boot in Windows
http://windows.microsoft.com/en-us/windows/using-system-configuration# 1TC=windows-7 Using System Configuration (msconfig) - Windows Help
DBerg5
I did not test the drivers Lenovo provides, mostly because they seem petty old.
Latest version there is 9.18.10.3272 from 11/6/2013.
Why are there different drivers for this one graphics chip anyway?
I get why when it comes to Multi-GPU notebooks, like Intel+Nvidia, but for pure Onboard graphics?
I did not try safe mode yet, but I will do that and report the results here.
Daniel
DBerg5
I started in safe mode now, looks like the error does not appear then.
Since in safe mode the Aero desktop design was deactivated, I thought I'd try to deactivate just that under a normal boot.
Seems to have worked. I have a very ugly looking Windows now, but no more flickering.
How am I able to tell now if this is a driver issue, or an error by some 3rd-party program?
Daniel
DBerg5
Does nobody have any advice for me on this issue?
Filip_Z_Intel
The easiest solution to check that is by disabling/removing graphics driver
DBerg5
I now tried the driver Lenovo provides, it gives me the exact same error.
When I deinstall the Intel driver and use the standard vga driver windows provides, the error does not appear.
Is anyone else here able to reproduce this error?
Jose_H_Intel1
I would install the driver again and try a clean boot as suggested above. This way you can try to determine if a conflict with a third party application is causing the issue.
If you disable all applications from startup and the issue does not happen, try enabling one application at a time to see which one triggers the issue.
DBerg5
I just installed the new driver v15.36.14.64.4080.
After a bit of testing it seems that the error does not show anymore.
To whoever fixed it, thank you!
Also thanks to everyone else here for all the advice.
Greetings,
Daniel
