23691 Discussions
HD Graphics 515 and OpenGl error
BAano
Hello!
I have an ASUS Zenbook UX305 With HD Graphics 515.
When I start the Application "Universal Gcode Sender" which is wiriien in JAVA, I am getting this error Message:
"Cant find the name of Intel ICD Open GL driver"
The current driver Version is: 21.20.16.4550
The ASUS updater says this is the latest approved driver Version.
If I try to install a newer, recommended driver from Intel, I get a warning;
"A customized computer manufacturer driver is installed on your computer. The Intel Driver & Support Assistant is not able to update the driver. Installing a generic Intel driver instead of the customized computer manufacturer driver may cause technical issues. Contact your computer manufacturer for the latest driver for your computer."
So, I contacted ASUS, and their answer was: "Sorry we can not help you. You must contact the software manufacturer"
What can I do now?
Regards Bent
Stefan3D
Try drivers from this list https://downloadcenter.intel.com/product/88354/Intel-HD-Graphics-515 Downloads for Intel® HD Graphics 515
Select OS from right pull-down menu. Hit "show more".
To bypass message "best driver is already installed", "customized computer manufacturer driver" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface (ignore prolog about MS surface)
NB current drivers for Windows 10 require anniversary update or newer
Stefan3D
BAano
Thank you, Stefan3D!
This was very helpful. The OpenGl error Messages have now disappeared!
Regards Bent
