22971 Discussions
HD Graphics 530 cause windows explorer crash
mmoha26
hi i have Dell Optiplex 5040 and when i install graphic driver i have a windows explorer crash
i know that you know about this problem but all the solution in the web don't work for me
is there any new solution
Hello simotech,
Thank you for contacting the Intel community.
Please try installing the latest graphics driver you can download it here:
https://downloadcenter.intel.com/download/26404/Intel-Graphics-Driver-15-45-?product=88345 https://downloadcenter.intel.com/download/26404/Intel-Graphics-Driver-15-45-?product=88345
Before installing the graphics driver, uninstall the old driver first; please see http://www.intel.com/content/www/us/en/support/graphics-drivers/000005598.html Uninstalling the Intel® Graphics Driver
Once the driver is uninstalled go ahead and install the generic driver from the link above manually.
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows 8*/8.1*
If the problem persists, could you please reply with a picture or a video if it is possible about the issue you have.
Also, I will appreciate if you could fill out the information at the following link:
/thread/77761 https://communities.intel.com/thread/77761
Ivan.
mmoha26
Hi, thank you for reply
the problem persist, in the attached files you find the 2 errors i got when installing any of your drivers
i had the same problem before but i installed a driver that fixed my problem
Now no one is good what should i do plz
Does this problem happens when you install the driver from Dell, Dell has the proper driver for your system and if you install the Intel generic driver some features can stop working.
We have tested this driver several times and we don't experience similar behavior.
Does this happen from the moment you purchased the computer or after sometime of using it?
You might want to try a system restore or you can try the troubleshooting steps at the following link:
https://answers.microsoft.com/en-us/windows/forum/windows_7-performance/windows-explorer-in-windows-7-keeps-crashing-and/c6fddc14-7649-4334-ac9a-6d049fd503bd https://answers.microsoft.com/en-us/windows/forum/windows_7-performance/windows-explorer-in-windows-7-keeps-crashing-and/c6fddc14-7649-4334-ac9a-6d049fd503bd
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Ivan.
Hello ,
I'm following on this post to ask you if your issue has been resolved or if you need further assistance.
Ivan.
mmoha26
i found a driver that worked for me
but when windows goes to standby the systeme reboot
Unforantalyi don't find a good solution for my issue
and to tell you i had the same problem with an HP machine but i found a driver on the net that works
if there is any news about this problem plz let me know
At least you found drivers that work for you, at this point I suggest you to keep checking the https://downloadcenter.intel.com/download/26121/Intel-Bluetooth-Technology-Based-Driver-for-Windows-10-and-Windows-8-1-for-Intel-NUC6i-x-SY-and-NUC6i7KYK?product=89189 Intel download center for new driver release or to run Windows update for new updates that can make your system run better.
Ivan.
