23784 Discussions
HD Graphics 630
CS5
Hello all,
I can't install my graphics driver for Intel HD 630. I always get the same error: "computer does not meet minimum requirements for installing the software".
I have the I7 7700k on a ASUS Z270f using Windows 10. BIOS is up to date, downloaded the latest driver from Intel, also tried the one from ASUS with no luck. Using the dedicated card all the time doesn't bother me that much, however I don't get it why it doesn't work.
Did anybody encountered this?
Thank you anticipated
Stefan3D
https://support.microsoft.com/en-us/instantanswers/e6bbddb0-9db4-4d88-9063-42c52c79a96e/create-a-system-restore-point Create a system restore point before you try anything.
Install the current driver build via "have disk method" as described at:
http://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
RAlva5
Same problem here.
АКоро3
Нужно войти в диспетчер устройств и добавить драйвер уже установленного устройства. потом просто выбрать из списка.
Hello Cosmas,
Thank you for contacting the Intel community.
I'm sorry that you haven't been able to install the graphics driver, if the method provided by Stefan3D does not work for you, you can try the following:
Uninstall the Intel® graphics driver if there is any older version install and also uninstall the dedicated card driver.
Once those drivers are uninstalled go ahead and install the Intel® Graphics driver first manually, please see how to http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows 8*/8.1*, after installing the Intel® driver you can install the dedicated card driver.
You can download the latest Intel® driver here:
https://downloadcenter.intel.com/download/26772/Intel-Graphics-Driver-for-Windows-15-45-?product=98909 Intel® Graphics Driver for Windows* [15.45]
I hope this can help you both.
Ivan U.
Hello ,
I'm following on this post to ask you if your issue has been resolved or if you need further assistance.
Ivan.
CS5
Hi Ivan,
unfortunately none of the two solutions work... i even took out the dedicated card.
Looking forward to solve this issue.
Thanks for the engagement.
Greets
Cosmas
Thanks for the information, in this case, if you remove the graphics card, do you mind trying again installing the Intel® driver as it is advised above.
Ivan U.
Hello ,
Ivan.
CS5
I eventually installed it... needed first of all to add it manually in device manager.
Thanks for the help !
I'm glad to know that you were able to install the driver, if you anything else related to this matter please let me know.
Best wishes,
Ivan U.
