23660 Discussions
HD3000 Win 7 64 Driver Crash
DCost3
I am having an issue when the new updated driver set for the HD3000 chipset is updated. I have updated it directly via the Windows update option, manually from intel,all with the same result. Once the new drivers are applied the system will not boot (blue screen). I have a Samsung samsung qx411-w02ub. My only option is to rollback the driver.
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7600.2.0.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: 3b
BCP1: 00000000C0000005
BCP2: FFFFF80002BBA90D
BCP3: FFFFF8800698FA40
BCP4: 0000000000000000
OS Version: 6_1_7600
Service Pack: 0_0
Product: 768_1
Jose_H_Intel1
Perhaps you want to try with https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23377 version 15.28.20.64.3347 or the driver provided by the system manufacturer, which should work because it was tested with your computer.
If the issue persists kindly provide minidump file found at: C:\Windows\Minidump.
You may attach more than one using the advanced editor when replying.
