23854 Discussions
HD4000 OpenGL Shading Language Texture bug?
Dear Support Team,
Our OpenGL-based library fails to run correctly on Intel HD 4000. After a lot of debugging, I've managed to isolate a problem that concerns building a custom mip-map-pyramid using shaders.
I've created a small reproduction case for this problem (source code is available at https://github.com/hetcomp/hpmc/blob/iss9/tests/simplemipmapbuildup.cpp https://github.com/hetcomp/hpmc/blob/iss9/tests/simplemipmapbuildup.cpp 😞
First, I create a mipmap'ed texture 2D and create an FBO for each level.
Then, I populate the base level with a GPGPU pass, and then use the following shader to reduce the pyramid:
uniform sampler2D tex;
uniform vec2 delta; // = vec2( -0.5/w, 0.5/w ), w is width of prev level
void
main(){
vec4 sums = vec4(
texture2D( tex, gl_TexCoord[0].xy+delta.xx )+
texture2D( tex, gl_TexCoord[0].xy+delta.yx )+
texture2D( tex, gl_TexCoord[0].xy+delta.xy )+
texture2D( tex, gl_TexCoord[0].xy+delta.yy ) );
gl_FragColor = sums;
using
for(GLsizei k=1; k<=size_l2; k++ ) {
glTexParameteri( GL_TEXTURE_2D, GL_TEXTURE_BASE_LEVEL, k-1 );
glTexParameteri( GL_TEXTURE_2D, GL_TEXTURE_MAX_LEVEL, k-1 );
to steer which texture level that should be sampled from.
The correct result is
Level 0
[0,0,1,1] [0,0,1,1] [0,0,1,1] [0,0,1,1] [0,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [0,0,1,1] [0,0,1,1] [0,0,1,1] [0,0,1,1] [0,0,1,1]
[0,0,1,1] [0,0,1,1] [0,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [0,0,1,1] [0,0,1,1] [0,0,1,1]
[0,0,1,1] [0,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [0,0,1,1] [0,0,1,1]
[0,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [0,0,1,1]
[1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1]
Level 1
[0,0,4,4] [1,0,4,4] [3,0,4,4] [4,0,4,4] [4,0,4,4] [3,0,4,4] [1,0,4,4] [0,0,4,4]
[1,0,4,4] [4,0,4,4] [4,0,4,4] [4,0,4,4] [4,0,4,4] [4,0,4,4] [4,0,4,4] [1,0,4,4]
[3,0,4,4] [4,0,4,4] [4,0,4,4] [4,0,4,4] [4,0,4,4] [4,0,4,4] [4,0,4,4] [3,0,4,4]
[4,0,4,4] [4,0,4,4] [4,0,4,4] [4,0,4,4] [4,0,4,4] [4,0,4,4] [4,0,4,4] [4,0,4,4]
Level 2
[6,0,16,16] [15,0,16,16] [15,0,16,16] [6,0,16,16]
[15,0,16,16] [16,0,16,16] [16,0,16,16] [15,0,16,16]
Level 3
[52,0,64,64] [52,0,64,64]
Level 4
[208,0,256,256]
However, when running the code on an HD 4000, I get the following:
Level 0
[0,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1,0,1,1] [1...
Marcos_U_Intel
We truly appreciate your feedback. Our software support and engineering group is working on future generations of this software that may implement better features. Your feedback for sure is important and will be forwarded to higher levels of support.
Thank you one more time for your interest in our products and how to improve their range of features.
Looking forward to assisting you further.
Michael
ROBERT_U_Intel
@cdyk Great work at narrowing down the issue with OGL. Your analysis was very helpful with debugging the issue. A fix will be available in a future release if the Intel HD Graphics driver. I will post an update when the driver is available.
