23831 Discussions
HD4000 Screen flicker after cold boot
EHoll
Greetings everyone!
My system configuration is as follows:
core i5-3570k, using hd400 igp
intel dh77kc motherboard
kingston 4GB DDR3 RAM Module (1 stick)
Win7 32 bit
Graphic Driver: Intel Version 8.15.10.2639
Monitor: LG, Resolution 1900x1200, DVI Cable
A few days ago I switched to the new motherboard above and refreshed the whole software installation.
From now on, when the system is booted from cold, there is a reproducible screen flickering for the first 5 Minutes after boot.
The screen flickers every 2-5 seconds and gets black for a second.
My previous board (Gigabyte z77ds3h) didn't have that issue.
Rebooting a "warm" system does not show that issue.
I've read in another thread here, that a similar problem was solved by switching to another driver version. As far as I know, I'm already using the newest driver.
Can anybody help?
Kevin_M_Intel
Hi mrAtari,
I am sorry to hear you are having problems but let me help you.
Based on the information you provided, there are some steps I want you to do:
1. Uninstall the current graphics driver. Here you have the instructions:
http://www.intel.com/support/graphics/sb/CS-034574.htm http://www.intel.com/support/graphics/sb/CS-034574.htm
2. Download and install the latest graphics driver for your system. Here is the download link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23406 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23406
EHoll
Hi Kevin,
I did as you told. The new driver version is now 10.18.10.3345.
Screen is still flickering on boot.
Kevin_M_Intel
Hi mrAtari,
I am sorry to hear you are still having problems. Please try clearing the CMOS in the board by disconnecting all components from the board and remove the battery for about 20-30 minutes.
Besides this, I recommend you updating the bios in your system. Here is the download link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22815 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22815
Here are some other steps you can try:
  1. Test a different power supply if possible.
  2. In the case you are using any video adapter/convertor try using direct connection.
  3. Test another cable if possible or a different connection.
