22964 Discussions
HD4000 not working after waking PC from sleep
Ci5-3570k, ASRock Extreme4, Windows 7 Professional x64.
Main display on a GeForce, Secondary display on the HD4000.
The computer goes to sleep alright, but after wake the secondary screen stays offline.
I have to go to system settings>system, disable the HD4000, enable it and it works again.
Quite annoying, same behavior with various drivers, currently running 9.18.10.3071, and on an unrelated sidenote, the Intel HD Graphics Control Panel could at least show the driver version
So any ideas?
DArce
Valued Contributor III
Lucid Virtu should work in two modes, i-Mode and d-Mode, in which the display should be connected either to the port integrated in the motherboard (i-mode) or in the discrete card (d-mode). The configuration should not be done as using one display in each of the video controllers, only one should be used
I am an CG artist and have used 2 Displays on 2 separate cards for years now.
After getting the i5 i decided the HD4000 was strong enough to fuel my secondary screen - and so far it's doing a great job, besides not waking up from sleep.
Thanks for your answer, but not using the HD4000, or only connecting one screen is not really a solution.
I already contacted Intel directly, maybe they can help. Can only be a problem with their driver, ASRock's drivers or a simple impossibility due to Lucid.
I'll see and report back.
