22854 Discussions
HD4600 Will "not" Support 3 Displays as specs indicate.
SSCOT8
HOPEFULLY this is in the right spot this time and won't get deleted. (I'm New Here, Sorry) ASUS BP1AD From Best Buy. Intel HD 4600 Graphics on Board. Your Intel Website says that card supports 3 independent displays. Reference http://www.intel.com/support/graphics/sb/CS-033714.htm http://www.intel.com/support/graphics/sb/CS-033714.htm - (Specifically, that's the reason I bought that box with that card). Have three identical monitors. All three equipped with HDMI, DVI, VGA. HD4600 Card has HDMI, VGA, DVI. Have one monitor each on DVI, HDMI, VGA. WILL "NOT" Support three monitors. Checked in Bios for options, checked drivers for updates. It will recognize all three devices connected, if I disable one, (edit for clarity: It will recognize any two I choose...but not three) but it will NOT function as that link says it will and do three at one time. Please advise.
ROBERT_U_Intel
Hi GreatPretender
The ASUS BP1AD will only support 2 independent displays at a time. It is likely a HW or BIOS limitation of the system. See page 31 and 72-73 of the attached users manual.
A workaround would be add a http://www.displaylink.com/ Display Link based port extender.
Specs:
Intel Core i7 4770 (3.40GHz)
  • 8GB DDR3 1TB HDD Capacity
  • Windows 7 Pro 64 bit / Windows 8 Pro 64 Bit
  • Intel HD Graphics 4600
  • Certificated by Energy Star 5.2
  • Support 2 Independent Displays
Robert
ROBERT_U_Intel
Hi GreatPretender
Specs:
Robert
SSCOT8
That is not the specs on this computer, (16GB DDR3, i5 Processor in this) though I'm fairly certain it's not going to make a difference. Either way, that's pretty stupid on ASUS' part...take a system that is more than capable of doing what we need...advertise is as "Intel HD Graphics 4600" without specifying any limitations...and then cut one-third of it off?
Sounds like ASUS has a problem misleading their customers.
Thanks Robert,
ROBERT_U_Intel
Out of curiosity are you able to connect a HDMI and DVI display at the same time?
Robert
SSCOT8
Yes, sir I am - that's what's odd about this. They're all ACTIVE..and they all WORK... just not all three at one times...which to me means the card is complete and functional..and after reading your response...I'm led to believe that ASUS did that...but I can't think of any logical reason.
ROBERT_U_Intel
You may want to contact ASUS to see if they have any information on this limitation.
Robert
