23719 Discussions
HDMI Problems with Windows 8 Media Center
I just upgraded my HP dv6t-3200 laptop from Win7 to Windows 8 Pro (64 bit) and am encountering problems with the HDMI port when using Windows 8 Media Center to play recorded tv shows. The video starts playing but immediately begins repeating the first few seconds of audio, then stops playing after about 5 seconds and says video file cannot be played. The problem only happens when playing the videos through the HDMI port to my TV. If I unplug the HDMI cable and watch the videos on the built-in laptop display, everything works fine. The HDMI graphics also work fine for normal desktop display, but won't play the media center videos properly. It appears to be a bug in the Intel HD graphics driver.
My adapter type is "Intel(R) HD Graphics". My chip type is "Intel(R) HD Graphics (core i3)".
If I try to install the latest driver 15.28.8.64.2875, it says "This computer does not meet the minimum requirements for installing the software."
I found a way to trick the driver into working. If I unplug the HDMI cable, launch media center and start a video playing, then plug in the HDMI cable, it will continue playing the video. I also discovered that "Windows Media Player" will play the recorded tv videos through the HDMI port but "Windows Media Center" will not.
NICHOLAS_F_Intel
Hi Steve,
Can you attach or copy/paste your dxdiag information please? (Start > Run > dxdiag > Save All information).
-Nic
Hi Nic,
I have the same problem. Please find the dxdiag information below:
Sandip
System Information
Time of this report: 11/24/2012, 20:31:04
Machine name: VAIO
Operating System: Windows 8 Pro 64-bit (6.2, Build 9200) (9200.win8_gdr.121023-1503)
Language: English (Regional Setting: English)
System Manufacturer: Sony Corporation
System Model: Reserved
BIOS: BIOS Date: 09/23/09 11:58:43 Ver: 08.00.10
Processor: Intel(R) Core(TM) i3 CPU M 330 @ 2.13GHz (4 CPUs), ~2.1GHz
Memory: 3072MB RAM
Available OS Memory: 3054MB RAM
Page File: 1218MB used, 4907MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Microsoft Basic Display Adapter
Manufacturer: (Standard display types)
Chip type: NVIDIA
DAC type: NVIDIA Corporation
Device Type: Display-Only Device
Device Key: Enum\PCI\VEN_10DE&DEV_0A75&SUBSYS_9072104D&REV_A2
Display Memory: 256 MB
Dedicated Memory: 0 MB
Shared Memory: 256 MB
Current Mode: 1360 x 768 (32 bit) (64Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: Nvidia Defaul
Monitor Id: SNY05FA
Native Mode: 1366 x 768(p) (59.940Hz)
Output Type: Internal
Driver Name:
Driver File Version: ()
Driver Version: 6.2.9200.16384
DDI Version: 11.1
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: DMA
Driver Attributes: Final Retail
Driver Date/Size: , 0 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: {D7B71AF4-43CC-11CF-9423-F003ADC2CB35}
Vendor ID: 0x1414
Device ID: 0x008C
SubSys ID: 0x00000000
Revision ID: 0x0000
Driver Strong Name: display.inf:10809047d4324726:MSBDA:6.2.9200.16384:pci\cc_0300
Rank Of Driver: 00FB2006
Video Accel:
DXVA2 Modes:
Deinterlace Caps: {00000000-0000-0000-0000-000000000000}: Format(In/Out)=(YUY2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{00000000-0000-0000-0000-000000000000}: Format(In/Out)=(YUY2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps...
KAndr6
Do you solved it ?
