23630 Discussions
HDMI no funciona (Intel 3000 graphics)
PGarc111
Buenas, tengo un DELL INSPIRON N5110 con una tarjeta gráfica INTEL HD GRAPHICS 3000.
No soy capaz de que funcione el HDMI, he mirado en la configuración del panel de control de gráficos de Intel, hay algo que me extraña pero no puedo seleccionar más de una pantalla en la opcion "Varias pantallas"
Tengo el último driver instalado
Adjunto la información que me da este programa a ver si podéis detectar el fallo.
Muchas gracias
Kevin_M_Intel
Hi gspablo,
The support provided in this community is in English only.
Based on your information, it seems that the multiple monitor function is not working. In this case, May I know if you have another monitor connected? If so, what is the connection you have?
Please post your dxdiag report or your graphics report so I can check more information.
PGarc111
Sorry for writing in spanish.
I detail the log get into the intel application.
Intel(R) HD Graphics 3000
Report Date: 11/21/2013
Report Time[hh:mm:ss]: 22:30:00
Driver Version: 9.17.10.2843
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: Spanish (Spain)
DirectX* Version: 11.0
Physical Memory: 4002 MB
Minimum Graphics Memory: 64 MB
Maximum Graphics Memory: 1696 MB
Graphics Memory in Use: 139 MB
Processor: Intel64 Family 6 Model 42 Stepping 7
Processor Speed: 2394 MHz
Vendor ID: 8086
Device ID: 0116
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 3000
Video BIOS: 2098.0
Current Graphics Mode: 1366 by 768
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Monitor PnP genérico
Display Type: Digital
Gamma Value: 2,2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 13,39 inches
Vertical: 07,48 inches
Monitor Supported Modes:
1366 by 768 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 0D AF A4 15 00 00 00 00
1B 14 01 03 90 22 13 78 0A 00 25 9E 57 52 99 29
15 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 00 1E 56 D6 50 00 2A 30 1A 38
4D 00 58 C2 10 00 00 1A 00 1E 56 D6 50 00 2A 30
1A 38 4D 00 58 C2 10 00 00 1A 00 00 00 FE 00 58
4D 35 58 47 02 4E 31 35 36 42 36 0A 00 00 00 00
00 00 00 00 00 00 00 00 00 01 01 0A 20 20 00 41
* Other names and brands are the property of their respective owners. *
