23538 Discussions
HDR Playback after Driver installation (latest Version)
EStam2
after installation of the newest Graphics Driver for my i7 7500U, the HDR Playback is broken.
Here is the System Scan txt.:
# SSU Scan Information
Scan Info:
Version:"2.5.0.12"
Date:"06.03.2018"
Time:"00:00:25.5865383"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"GIGABYTE"
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends Inc. F4 , 02/20/2017"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Mobile"
Processor:"Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz , GenuineIntel"
Secure Boot State:"Off"
SMBIOS Version:"3.0"
Sound Card:"High Definition Audio-Gerät"
Sound Card:"Intel(R) Display-Audio"
System Manufacturer:"GIGABYTE"
System Model:"GB-BKi7(H)A-7500"
System SKU:"Default string"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"24.20.100.6094"
- "Intel(R) HD Graphics 620"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1,00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) HD Graphics 620"
Link:" http://www.intel.com/content/www/us/en/search.html?keyword=HD+Graphics+620"
CoInstallers:"C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_b963b5cf9ef8a8d1\igxpco64.dll, CoDeviceInstall"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmd64.sys"
Driver Date:"05.16.2018 02:00"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\igdlh64.inf_amd64_b963b5cf9ef8a8d1\igdkmd64.sys"
Driver Provider:"Intel Corporation"
INF:"oem5.inf"
INF Section:"iKBLD_w10_DS"
Install Date:"Not Available"
Installed Drivers:"C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_b963b5cf9ef8a8d1\igdumdim64.dll,C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_b963b5cf9ef8a8d1\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_b963b5cf9ef8a8d1\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\igdlh64.inf_amd64_b963b5cf9ef8a8d1\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_5916&SUBSYS_10001458&REV_02\3&11583659&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"59 Hz"
Refresh Rate - Maximum:"120 Hz"
Refresh Rate - Minimum:"23 Hz"
Resolution:"3840 X 2160"
Scan Mode:"Noninterlaced"
Service Name:"igfx"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) HD Graphics Family"
- "Memory"
Physical Memory (Available):"13,33 GB"
Physical Memory (Installed):"16 GB"
Physical Memory (Total):"15,85 GB"
- "BANK 0"
Capacity:"8 GB"
Channel:"ChannelA-DIMM0"
Configured Clock Speed:"2133 MHz"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"SODIMM"
Interleave Position:"First position"
Manufacturer:"859B"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"CT8G4SFS8213.M8FA"
Serial Number:"E0459C10"
Status:"Not Available"
Type:"Synchronous"
- "BANK 2"
Capacity:"8 GB"
Channel:"ChannelB-DIMM0"
Interleave Position:"Second position"
Manufacturer:"859B"
Serial Number:"E0459BC4"
Type:"Synchronous"
- "Mother...
Hello Case39,
Thank you for contacting us.
I understand that are experiencing issues in your system after updating to our latest Drivers.
Based on the report that you sent, we noticed that your graphic drivers are indeed up to date, so before taking a deeper path, let's go ahead and try installing previous versions so we can discard the latest one as the root of the issue:
https://downloadcenter.intel.com/download/27484/Intel-Graphics-Driver-for-Windows-15-65-?product=96551 https://downloadcenter.intel.com/download/27484/Intel-Graphics-Driver-for-Windows-15-65-?product=96551
https://downloadcenter.intel.com/download/27680/Graphics-Intel-Graphics-Driver-for-Windows-10 https://downloadcenter.intel.com/download/27680/Graphics-Intel-Graphics-Driver-for-Windows-10
If one does not work, please go ahead and try the other one and monitor the results.
As well, can please provides with a longer/more detailed description of your issue?
I hope to hear from you soon.
Best regards.
Diego S.
EStam2
After install of the latest driver, the OS is not more accesible in any way I have to reinstall it
RonaldM_Intel
Hi Case39,
Let's keep this conversation in one single thread.
I'll lock this one, please continue in the 1st thread created for this issue
Ronald M.
LuX1o
hy! 🙂
do you can play hdr now?
i have the same problem same pc
