23722 Discussions
HELP!!! Intel graphics hd control panel - Collage mode (only) cannot find laptop's built in display as part of collage gaming. Used to work perfectly on many games and now it does not even collage all three displays. This did seem to be after windows 10 u
AToml
I used to play many games on my laptop connected to two external displays. I did it by selecting colalge mode and using alll three screens - including the laptop build in display. When i updated to windows 10 the intel hd graphics control panel could no longer add the build in laptop display as part of the collage - only the two external monitors. This has made me quite sad because i bought the two external screens to play games in eyefinity/collage/widescreen gaming Really need help have not found anyone else facing this. Liek i said it did work perfectly!
Bryce__Intel
Hi AlexusT
I spoke with the engineering team on this and received an explanation as to why this is no longer working in Windows 10.
Microsoft changed the way we can implement this in Windows 10. The LFP [Local Flat Panel - aka laptop display] is no longer included in collage mode options starting with Windows 10 and this is expected behavior per the new implementation moving forward. Only EFP's [External Flat Panels] will be available choices in collage mode options.
Jose_H_Intel1
Please provide your http://www.intel.com/support/graphics/sb/cs-009476.htm Intel® HD Graphics report and DxDiag report (press Windows* key + R key, type "dxdiag", press OK and then click "Save All Information").
In order to attach files, make sure you select the "Advanced Editor" option in the top right of your reply window. You will then be presented with an attach file dialogue at the bottom of the reply.
AToml
I've ensured to do this whilst being connected to the two external monitors. So glad help has arrived.
Let me know if there's anything else i can do.
Alex
AToml
Hi - It is possible to get your feedback on this - Did you get a chance to look at this?
Alex
Ricardo_G_Intel1
I suggest to :
1.Make sure Windows is up to date, run Windows Update.
2.Check MSI Home Support, to view the latest laptop drivers. these drivers are customized by MSI to specifically work for your model. http://us.msi.com/support http://us.msi.com/support
3.Try downloading from Intel®'s web site https://downloadcenter.intel.com/ https://downloadcenter.intel.com/ the latest, graphics drivers https://downloadcenter.intel.com/product/81496/Intel-HD-Graphics-4600-for-4th-Generation-Intel-Core-Processors https://downloadcenter.intel.com/product/81496/Intel-HD-Graphics-4600-for-4th-Generation-Intel-Core-Processors , these are generic drivers for the Intel® HD Graphics 4600.
Bryce__Intel
Hi AlexusT
