23047 Discussions
Heavy frame drops in-game
Frank1102
Whenever I try to run The Witcher 3 or Middle-Earth Shadow of Morder, the game runs great at 40-60 fps and then drops to 2-3 fps, I don't think it happens during the Tomb Raider games, but I am not sure. It even happens in the menu when I have the games on pause. I have checked the temps and they seem okay.
The laptop I am running on is a:
Lenovo Thinkpad X1 yoga Gen 6
I7-1185G7
32GB ram @ 4266 MHz
In case you need more info, let me know.
Thanks in advance.
1TB m.2 2280 SSD, PCIe gen 4
Frank1102
I have found a long threat on the Lenovo forums which explains this same issue:
https://forums.lenovo.com/t5/ThinkPad-X-Series-Laptops/Lenovo-X1-Carbon-Gen-9-Throttling-Issues/m-p/5073083?page=1
Here, Lenovo has confirmed that there is a problem and they say there will be a BIOS fix soon. The same problem is also mentioned in a review on Notebookcheck.
I will have to wait for the BIOS update.
ReX_TeCH
Hope you are doing well, thanks for posting your query.
Hope this information helps: https://forums.lenovo.com/t5/Gaming-Laptops/Huge-overall-FPS-drops-in-most-games/m-p/4162848?page=1#4162848
Otherwise try updating BIOS, graphics drivers https://downloadcenter.intel.com/
And after this also if the issue exists contact your manufacturer https://support.lenovo.com/in/en/
Please let me know how it goes.
ReX_TeCH
(Independent Advisor)
Frank1102
Thank you for your reply,
I have tried holding down the power button for about one minute, but it did not work. At first I thought the problem was fixed because it took a while before the problems came back, but they did. I tried the power-button trick again and this time nothing changed.
When monitoring my power usage, core frequency, temps etc. I noticed that my core frequencies seem to drop when the frame rate drops. When everything goes well, frequency is around 3.3 - 4.5 GHz, but when the game stutters the frequency drop to about 400 MHz, until the game picks up again. The temps were not exceptionally high before the game starts lagging, so that seems to not be a reason.
Kind regards,
Frank
Frank1102
