22988 Discussions
Hello. Could you please let me know about EPI, Embedded Panel Interface. I heard this interface specification is based on EDID 1.3. I need to design a control board connected to displays with EPI interface. Thank you.
MSaka19
Esteban_D_Intel
Hello MSaka19,
Thank you for posting on the Intel® communities.
As this is a design that you are working to better assist you I would recommend checking the Resource & Design Center for Development with Intel for further technical information and resources for your design.
Also, you may want to contact an Authorized Distributor in order to check with a Field Application Engineer (FAE) for the appropriate support.
Esteban D.
Intel Technical Support Technician
MSaka19
Hello Esteban D,
Thanks for your kindly return.
OK, I will check the Resource & Design Center for Development with Intel, and if I don't clearly get it, I consider to contact FAE.
Msaka 19
